Question about GE Spectra JGBP30 Gas Kitchen Range
Oven and Broiled will not light - GE JGBP30 oven
The oven or the broiler will not light. Is it the ignitor? It looks like the the broiler and oven have separate ignitors. Or could be some other control that is not working.
  • Anonymous May 10, 2008
    My GE Spectra XL 44 range has the same problem. Oven nor broiler will not light. Purchased unit 2001, Had to replace bake igniter already once in 2003.Also, range top burners must be lit most of the time with matches. Clicking noise is very faint sometimes and once it is lit it will click normally. Simmer burner is so low it is not worth using. Of course it is out of warranty.Very disappointed and inconvenienced.
  • GE Master
  • 5,568 Answers
I think it was the 'Guest' who commented on this and we just exchanged information again.
You can read it here:
GE Oven-Broiler problems
Posted on Dec 28, 2008
GE oven/broiler problem: oven works, broiler does not light. Model JGRPP17WEW4WW
This would also go for the broiler also...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 24, 2010 | GE JGBS23 Gas Kitchen Range
I have a GE JGBP30 gas range. The oven is taking
Quiet possibly, but make sure there are leveling legs installed and the front edge of the range is not blocked by any flooring. It may be that the oven is not receiving enough combustion air. (sometimes happens when flooring is replaced and legs are removed so the range is not higher than the countertop, or a layer of flooring is added to the room and buts up against the range, where flooring was not added.)
Jul 04, 2010 | GE Spectra JGBP30 Gas Kitchen Range
Broiler works - oven won't heat - smell gas
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jun 03, 2010 | GE Spectra JGBP30 Gas Kitchen Range
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Gas GE Range
need to replace ignightor in oven
Dec 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
The oven won't light, it is a gas oven. The top (broiler) lights but the oven won't light. Thank you.
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Oct 20, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Ours is a xl44 spectra oven will not ignite, broiler sometimes.
Don't you regret now to have shoved your old range out the door? Sorry, it just seems that each time we replace something we end up regretting it.
Your problem is appparently not uncommon and while the model numbers differ, I think you will find the solution in the discussion lined below:
Oven-Broiler ignition problems
Dec 31, 2006 | GE Spectra JGBP30 Gas Kitchen Range
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
344 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
