Question about Refrigerators
Small fridge My 4 month old fridge westinghouse ( top freezer compact) sorry don't know the model was leaking water into from the freezer into the fridge though where you regulate the temp. On investigation i noted that the temp had been turned down (suspect my grand daughter) i turned it back up to medium now the freezer is making snow around the door and the fridge is quite warm. help please do i need a call out ?
  • cheekybeth Feb 10, 2008
    Whooo hooo that worked thanks a lot
    Novelist:
  • 87 Answers
Empty the fridge freezer and defrost completely (suggest overnight). The freezer section has a coil behind the back wall normally and what you have described is a frozen coil. Then restart the system. If the thermostat or temporary fault was the reason then this should cure it. If your problem reoccurs within three weeks then you might have a defrost problem. If you do have a problem then make sure you get straight back to where you bought it from as soon as possible a you should not be charged. Hope this is of some help.
Posted on Feb 08, 2008
Fridge leaking water
The drain line may be misdirecting the defrost water so that it misses the pan or the pan may be damaged or mispositioned.
Dec 03, 2013 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Fridge not getting cold...but freezer is working
the fridge gets its cold air from the freezer fan blowing it through small air passages between the freezer and fridge. when you adjust the temperature in the fridge you are increasing/decreasing the amount of air being let into the fridge. Two common problems that could cause the freezer to freeze but not the fridge getting cool is the freezer coil is frooze like a ice cube blocking the air going to the fridge or freezer fan is not working could be bad or froze up due to too much ice. If fan works after manually defrosting problem could be in the auto defrost mechanism. If fan don't work after manual defrost replace fan. Manual defrost by putting a pot of very hot water in freezer with door closed change water foten until defrosted.
Jan 02, 2012 | Westinghouse Avalon Refrigerators
I have a whirlpool refrigerator, model GR9FHMXPQ. I got it about 4 years ago. When it was delivered, it had several pieces of styrofoam lodged in the inside ceiling of the fridge section (below the freezer...
You need to remove all of the styrofoam packing material.
Any insulation material would be installed inside the body of the fridge/freezer. The packing material is there so anything inside the compartment (like metal shelves, plastic holders, etc. don't bounce around during shipping and either scratch up the interior, or break. That is all that it is there for.
Apr 25, 2017 | Whirlpool GR9FHMXPS Stainless Steel Top...
Water in the bottom of the fridge this unit is 15 years old
the seals or door gaskets leaking will cause fuzzy ice to grow in freezer and water to collect in frige and run alot
Dec 27, 2009 | Westinghouse WWS833ES Super Capacity Top...
My 11 year old fridge has a slight leaking problem. on occasion i will find a small puddle in front of the fridge and sometimes a little bit of water under the right side crisper but i can't seem to find...
Hi, The drain hole for this model is located in the control panel. There should be 2 - 4 screws that hold the panel up. remove those screws and the control panel should drop down. Flush the drain hole out and check up inside the hole leading to the freezer drain and see if there is ice inside the drain hole.
Most of the time, the drain inside the control panel is the problem.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Magic Chef CTB1922 Top Freezer...
Freezer works, fridge not cooling but water was leaking from under fridge a few weeks ago, could not find source . Small compact frigidaire unit for dorm room.
Most if not all fridges under $2000 only use a single compressor meaning the refrigeration is provided by venting the freezer air into the compartment. Water under the unit likely indicates the fridge is not properly sealing and moisture is condensing on the cold coils and dripping.
Jun 24, 2009 | Refrigerators
Water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Jun 17, 2009 | Refrigerators
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
