Question about Panasonic PT-53WX42 53" Rear Projection Television
No Video or Sound. Power Light Blinks 5 times = IC4011. Where do I go from here?
  • 4 more comments
  • Rhino-AE Feb 08, 2008
    Where is this transistor located? I have the service manual. This is my first attempt at tv repair. Is it a pretty good bet that the transistor is bad? I have a multimeter. I am having trouble figuring out how to ground it to get good readings. The only thing I have figured out is putting the negative in the wall socket ground and I am able to read for 115 to the power cord junction at the circuit card. How would I check this cap? Should I just replace the cap and see what happens?
    Where is the this Cap?
    I need more help locating this cap. Are you speeking from experience with this exact model? Can you give me a list of parts I should change? I will order them and change them all.
    AFDASDG
    I have plenty of experience working with live ciruits just not at the ciruit card level. I am capable of pulling the board and having a pro put the parts on for me. If it would make you feel more comfortable I won't mess with it live anymore.
    If you are concerned with my comment about sticking the negative lead in the ground on the wall socket, I am aware that this is not a safe practice. I can do this. Please help me.
    Problem Solver:
  • 6 Answers
Check for open resistor (R800) 1.5k ohm 5 watt resistor near the AC line.
Posted on Feb 27, 2012
  • Panasonic Master
  • 5,138 Answers
Check your hori out put transistor NTE2973 & 1200pf & 2kv capacitor next to it,most of the time this is what is bad .
ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 08, 2008
  • ladywinn
    ladywinn Feb 08, 2008
    My best advice to you is for you to take your set to a tv repair shop before you get hurt ,these tvs carry some very high voltage and if you get across RF voltage it can kill you!
  • ladywinn
    ladywinn Feb 09, 2008
    The capacitor that you are looking for is small blue cap 2kv the hori out put is next to your Flyback Transfomer it will be solder in by 10-11 pins holding it in circuit it has 1 wire going to high voltage trippler/other wire goes to screen drive control also look for open pico fuses.
Panasonic 42 inch television
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Stand By Light Flashes 5 Times - No Video Or Sound
IKR Error at power on 05. This is the fault. it is related with its main digital processor board itself. For more information go to http://electronicshelponline.blogspot.com/
Nov 27, 2013 | Televison & Video
No Video Or Sound - Stand By Light Flashes 5 Times
If the tv was made before December 2008, there is a capacitor settlement from a class action lawsuit by Samsung. Supposedly (at no charge) they will send a repairman to replace the capacitors.
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
52 inch panasonic projection tv won turn on and flashes what appears to be a diagnostic code?
The most common error codes are when the set does not turn on the power light on the front blinks in a sequence---most common is 3 blinks, a pause and 3 blinks etc
If you have to, unplug the set and try to turn it on again and see what the sequence of blinks is.
Let me know what you find and I will try to tell you what it means.
rate this solution as I do this here for Free.
SD TECH
Nov 27, 2009 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
IC4011 INDICATED CIRCUIT FAILURE
this trans sister and cap is going to be close to the hot which is high voltage be careful !!!!! the hot is a big red some times black with red thick wires, the transistor will have a silver(or black) heat sink with this larger transistor attached to it. the cap is going to be right by it
Feb 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
TV Quit working
5 blinks = IC4011 however doesn't always mean ic is bad.
Feb 01, 2008 | Televison & Video
Panasonic PT-53WX42 53" Rear Projection Television Logo
96 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
