Question about Baby Gear
1985 Cavalier replaced coil, fuel pump works, injection system works, will not start.
  • motboc Feb 08, 2008
    I still have no spark from the coil could it be the ecm
  • motboc Feb 10, 2008
    I have no spark so I replaced coil, still no spark
  • 2,039 Answers
Our saying you have spark you see gaz straying from injector if you have spark and gaz it have to start unless the timing chain has jump i be suprise of that one to check that out 1st remove spark plug cylinder 1 turn the engine untill you see the piston on topthat meen our number 1 piston is in compresson go on our crank shaft poulie lock at the timming mark if its 0 top dead center that mean our timming chain good you need to have spark at the spark plug from coil to cap on wire to spark plug check that out if any more help im pierre235 thanks for using fixya pierre
Posted on Feb 08, 2008
  • pierre laplante Feb 08, 2008
    when you put the kee on do you have a check engine light that come on if no check fuses maybe ecm fuses or at the positive side of battery you have the starter cable and you have a little wire it a fuse older pull on the wire if you have a check engine light take a test light kee on you suppose to have power to the coil if so next get somebody to start our car by now the only thing left take our test light start the engine you should have electric pulse to the test light the test light should have fast blink if not the ignition module in the distributor is dead i ghange lots of them but say lot of broken battery wire you have a little plastic black cap that hold that cable they corode pull on it if it week it gonna break thanks for using fixya pierre235
  • pierre laplante Feb 10, 2008
    did you do what i told you follow it that the only thing to do if you dont understand something let me know pierre
I have 1985 4.3 fuel injection Monte carlo that when driven for more than 20 to 30 min it will began to boog out or idle down so far that it will cut off and if u try to restart it, it wont start unle
Sound like a lack of fuel. Since you have replaced most of the ignition parts, I would look at the fuel system next.
Could be a clogged fuel filter, weak fuel pump, or pump relay.
Apr 28, 2013 | 1985 Chevrolet Monte Carlo
I have a 1985 6.2 diesel if u let it sit over night it real hard to start u got pour fuel down the intake to get it started glow plugs seem fine
check fuel line for minor leaks and check valve also check the filters sounds like air bound problems
Nov 09, 2011 | 1985 GMC C3500
91 chevy cavalier 2.2 engine turns but that's all . ECM ,coil,fuel injecter,fuel filter, and intank fuel pump replaced 2 days ago.
OK FIRST PULL A WIRE OFF A PLUG CRANK ENGINE OVER AND CHECK FOR SPARK. THEN YOU ARE GOING TO HAVE TO CHECK FUEL PRESSURE. THIS HAS TO BE DONE WITH A GAUGE TO SEE IF YOU ARE HOLDING 9-13 PSI ONCE YOU FIND OUT WHICH ONE IS MISSING YOU CAN FIND THE PROBLEM. IF YOU HAVE BOTH IT IS TIMING . THIS VEH HAS A TIMING CHAIN. SO FIND OUT AND RE POST AND WE CAN HELP YOU GET THIS STARTED.
Feb 13, 2010 | 1991 Chevrolet Cavalier
Where is the feul pump located on a 1985 honda accord
If you car is fuel injected the pump is probably inside the gas tank!
You can check under the floor mats back in the hatch/trunk to see if you have an access panel. The pump sits right under it.
Good luck and be careful.
Jan 19, 2010 | 1985 Honda Accord
97 dodge nostart no power coil, injecter, fuel pump run with key on.
Semi electronic system--replace the brain..full electronic --same.
Oct 12, 2008 | 1998 Dodge Dakota
1985 chev cavalier w/ fuel injection carb
It sounds like a throttlebody sensor is at fault here there are 2 sensors on the older throttlebodies
May 16, 2008 | 1985 Chevrolet Cavalier
Baby Gear Logo
42 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
