Question about Intel Motherboard
Electrical? noise My sony desktop has developed a HIGH whine/hum to it & it takes 20 minutes to load now. Any ideas what is wrong & how do I fix it? It's about 5 years old. My email is rlhoudyshell@verizon.net THANK YA"LL
  • loboblanca Feb 09, 2008
    Did defrag, disc clean up EVEN a restore.......did not resolve .Humming still loud & still takes 20 minutes to load.
Why dont you try defragement it and see what happens.
Posted on Feb 08, 2008
I have a magnavox 37mf331d/37 that has developed a high pitched whine.the longer the tv is on the louder the whine.the tv is 5-6 yrs old
It's likely a capacitor associated with the power supply having gone bad.
It's obviously beyond your expertise to repair it yourself.
Find a trustworthy repair shop and take it there.
Sep 05, 2012 | Televison & Video
When I get up to about 65-70 mph with my 2004 Lincoln Navigator it makes a humming noise... very annoying.. Can anyone help me with what this is and how I can get it fixed?
Unfortunately, this is a somewhat common problem. Ford has issued several Technical Service Bulletins related to rear end noise. Without an extended warranty, this is something you will have to pay for.
TSB 05-23-3 11/28/05 REAR AXLE NOISE REPAIR FORD: 1997-2005 Expedition, F-150 2002-2005 Explorer LINCOLN: 1998-2005 Navigator 2003-2005 Aviator MERCURY: 2002-2005 Mountaineer
ISSUE:
Some vehicles may exhibit an axle whine or hum during acceleration, deceleration and/or cruise.
ACTION: An axle repair kit has been developed which incorporates most parts required for a comprehensive axle repair. The kit should be used instead of installing a complete axle assembly to repair an axle whine/hum. Replace Ring and Pinion with Axle Kit and Components.
Mar 20, 2011 | 2004 Lincoln Navigator
I have a Sony STR-DG520 5.1 receiver. My problem is that I can hear a high pitched background whine from all the speakers, even if the volume is set to zero or muted! If I switch the audio source off, the...
do u have the unit earth grounded? sounds like AC hum, most amps have a ground lug, make sure that is grouned and the power plug to o the amp has a good ground.
Jun 15, 2010 | Sony STR-DG520 Receiver
When we start our dryer it makes a loud noise as if it struggles to get the drum moving. Once the dryer is moving it has no trouble moving, but every time we start it, the noise happens again even if i was...
Is this noise like a loud buzz or hum? If it is it may be the motor draging
and can't quite get going. bearing getting worn.
Also check drum rollers or glides and the idler pully one of them may
be dragging if they are you might put a little high temp oil on it.
Hope this helps..
Jan 25, 2010 | LG DLE2532W Electric Dryer
Whining noise while accelerating in 1st gear
Check the idler and tensioner pullys for your serpentine belt. I suspect the whining noise heard earlier was due to the fact one was getting a bit stiff or rough turning. When you gave it that extra fuel, the sudden load may have finished it off. Sometimes they lock up, and sometimes they fall apart. Check those items first.
Aug 26, 2009 | 2006 Audi A3
Deceleration whining/humming noise
I would tell the dealer you want your rear differential opened up, checked, and more fluid added. There really is no test they can do other than to pop the cover off the differential.
Jun 01, 2009 | 2009 Jeep Grand Cherokee
Dyson vacuum cleaner doesn't start
check if something is stuck to keep the motor from turning
Mar 18, 2009 | Dyson DC05 Bagless Canister Cyclonic...
A high pitched whining noise in the engine.
This Noise Description sounds Indicative of the Sounds that come from the Serpentine Belt Or Related parts such as Belt Idler Pulley or Belt Tentioner witch also has a Pulley, but if Tensioner itself is Literally BROKE I've replaced a number like this it will cause a Whining noise . Best case scenario its just the Belt, and if any of the other Problems turn out to be the Culprit the Belt MUST be Replaced Anyhow as Damage is Being caused By the Very Whining you hear.
PLEASE Spend the Extras $ for the BEST BELT as this Drives your Water pump, Alternator, A/C Compressor, Power Steering Pump All Crucial to Control of, easy Steering ,All Electrical-Power Distribution, The COOLING of Engine << VERY CRITICAL Component
The Pulleys usually have a more Hum type Whining. So I would say at Best The BELT , And WORST Belt Tentioner is Broke
Jan 14, 2009 | 2002 Dodge Caravan
Whining noise from freezer
Fan motor is bad and needs to be replaced.
Nov 26, 2008 | Refrigerators
Interference?
You must use a UPS on your PC set.
Jun 24, 2008 | Logitech X-240 Computer Speakers
Intel Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
