Question about Westclox Presto 80199 Clock Radio
Westclox Westminster Chime
The pendulum in my Westclox Westminster Chime clock has stopped swinging. I have tried fresh batteries trying to make it swing but it doesn't work anymore. I have tried to find new "guts" for it but cannot. Can you help?
Brad
3 Suggested Answers
studio500
  • 36 Answers
SOURCE: Need instructions
http://www.westclox.co.uk/
Contact them through the contact us link and I'm sure they can assist.
Marc
Posted on Apr 17, 2009
SOURCE: changed battery and now pendulum wont swing
Give the pendulum a shove and do it every time you pass the clock. I got mine going from swinging for just 20 seconds to working permanently, at least until the next battery change.
Posted on Apr 15, 2010
How to turn-off chime of elgin Westminster chime wall clock with pendulum?
Are there two batteries. One for the time and one for the chime? Try taking the one for the chime out and it should stop chiming. mine worked that way but is a different make.
Feb 04, 2017 | Elgin Watches
I have a Dakota Daniels grandfather clock. The chimes work, the pendulum works, but the clock hands don't move.
Change the batteries. The weight makes the pendulum and chimes work, but the clock in this thing is battery operated :>)
Accurate hourly Westminster chime movement tolls the hour - Automatic night shut off
  • Cathedral pediment, blue moon metal dial with raised roman numerals
  • Pendulum, weights and chains are made out of metal - Real tempered glass
  • Sturdy construction - Made of MDF & solid wood - Batteries (3-AA & 2-C) not included
  • Dakota Daniels grandfather clock Google Search
    Dec 12, 2016 | Dakota Watches
    Pendulum wont swing
    Clock may either need to be decked out from the wall at the top, or pushed all the way up against the wall. These clocks have inexpensive quartz movements that aren't of the highest quality. If the clock is more than a few years old, it may be that the electromagnet that impulses the pendulum back and forth has just expired. You might try Clockit.com, or maybe Timesavers.com to find a replacement movement. Hope this helps, Good Luck
    Dec 04, 2013 | Sterling & Noble Scroll Pendulum Wall...
    I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
    I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
    Perhaps your is the same?
    Mar 13, 2011 | Watches
    I do not know how to start the clock : Clock under glass. Has three balls supposed to swing. I replaced the battery.
    Lift the glass and swing the pendulum/balls. Or you could, if it's small enough to hold in your hand, suddenly twist it, there by using inertia to swing the pendulum.
    Aug 03, 2010 | Watches
    I have a Seiko Westminster Whittingham Clock, which keeps perfect time, but the pendulum won't swing for more than a couple of minutes. Does anyone know what's causing this? Bob
    mcdevito75 here, I would figure the pendulum serves 2 purposes, 1 it acts like a seconds hand on a watch and 2 more important it acts a s a counter weight keeping the clock in Balance. It sounds like the Pendulum mechanism needs cleaning and or adjustment, look for a small watch repair shop in your area, they can advise you on a clock repair shop in your area, or you can always check with the repair service directory right here at fixya, bottom of page, click on repair service directory the watches / clocks.
    Jul 03, 2010 | Seiko Mantel Clock
    Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
    First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
    Jan 28, 2010 | Watches
    Changed battery and now pendulum wont swing. Clock doesn't operate at all. All was fine until I changed the battery.
    Jul 07, 2009 | Howard Miller 645-627 Clock Radio
    Westclox Presto 80199 Clock Radio Logo
    115 people viewed this question
    Top Westclox Audio Players & Recorders Experts
    Joseph Hoffmann
    ray gallant
    Tom Chichester
    Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
