Question about Lexmark JetPrinter X1185 All-In-One InkJet
Scanner do not run but printer does - Lexmark JetPrinter X1185 All-In-One InkJet
  • Ellen8 Feb 08, 2008
    My Lexmark X1185 worked perfectly until today! It no longer scans or makes copies.
    Scholar:
  • 45 Answers
I suggest you;
1.) uninstall your X1185
2.) download the latest driver for the X1185 at
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X1185
(Be sure to select the driver which corresponds to the Operating System you are running on your PC)
3.) reinstall the X1185 using the newly downloaded driver
Hope these guidelines help you to solve the problem
Kind regards and thanks for using the FixYa service
Posted on Feb 24, 2008
My scanner wont work because I have run out of coloured ink - shouldnt I still be able to use the scanner??
having no ink should not affect the running of a scanner
make sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
select properties again you will have the similiar options also have option to troubleshoot
hope this helps you
Oct 25, 2011 | Canon PIXMA MP610 InkJet Printer
Control center 4 not showing all brother scanners installed in my network
I'm running into the same problem. I'm now under the impressions that certain scanners run under different versions of Control Center. I have Control Center 2, 3 and 4 running three different scanners with no obvious way to combine them into one control center.
Oct 14, 2011 | Brother MFC-7820N Printer
Cant get the scanner software to work
Try reinstalling the software using the drivers from HP.com. If you go to HP.com and type in the model number into their search bar it will usually pull the printer right up. Then select drivers and downloads and find the software using your operating system. Simply download and reinstall the software and it should work just fine.
Mar 01, 2011 | HP Officejet 5610 All-In-One InkJet...
I changed from a win.98 to an xp the scanner quit
Sir,
I have lost the hp scanjet 3200c scanner. pls give me this driver
Nov 09, 2009 | HP ScanJet 3200C Flatbed Scanner
My pc is not recognizing the scanner
In your printer and fax folder you probably have more than one printer installed and your default printer is not the one you just installed, Select the printer you just installed and set it as your default and try again
Jun 19, 2009 | Uniden BCD996T Base Scanner
After running full system recovery I tried to reinstall my printer and scanner. I reinstalled my printer (HP Deskjet 870ces). Then tried to reinstall HP Scanjet 5100c on a machine running Windows XP Pro....
Some time printers and scanners conflict. Try this, uninstall both printer and the scanner, then install the scanner first and try it to see if it works. Then install your printer. If it doesn't work let me know I'll walk you through. Good luck :)
Feb 21, 2009 | HP Office Equipment & Supplies
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner problem
reinstall the driver for the printer from this site:::
http://www.support.xerox.com/go/results.asp?prodID=XK35c&Xlang=en_US&Xcntry=USA&Xtype=download&prodName=WorkCentre%20XK35c
Oct 23, 2007 | Xerox WorkCentre XK35C InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
175 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
