Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune The washer makes a intermittent squeaking noise on the wash cycle
  • 2 more comments
  • dpgdc Feb 08, 2008
    The squeaking noise only happens on the wash cycle, not on the rinse or spin
  • tirebill Feb 08, 2008
    The washer also makes a intermittent squeaking noise on the wash cycle. I agree the squeaking noise only happens on the wash cycle, not on the rinse or spin. (This was posted by dpgdc on Feb 08, 2008).
    I have the exact same situation. I don't belive it's a leveling problem.
  • Anonymous Dec 08, 2008
    I also have this problem and it is level as it should be. it squeeks when the
    washer reverses directions not normal
  • Mark Van Horne Dec 19, 2008
    our Maytag Neptune had those same squeeks, just before the circuit blew and we had to spend 400 dollars to get it running again.  Now it works, but still squeeks!!
Your machine may be out of balance. It could be that your loads are not well dispersed (such as mixing a load of socks with a bedspread...). Or it could be that your machine is not level on the floor it is sitting on. Sometimes that will be an issue. I have had squeaking sounds before and those helped me, that said, I also tried to find your manual and look in the "trouble shooting" section, but the link was broken.
I hope this helped at least a little!
Posted on Feb 08, 2008
  • Patte Luse
    Patte Luse Feb 08, 2008
    I am still looking for your owners manual from the factory... 884fearless...
Maytag neptune tl...shows op code but the lid is closed and locked and will not unlock.
my he maytag makes a squeaking noise and it wont fill up. could there be a sock stuck in there or something. and the lock wont lock.
Oct 26, 2013 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
MAV-3 top load washer makes loud squeaky noise during the wash cycle.
Is it a constant squeak or does it go squeak-squeak - squeak as it agitates? It is a squeak that is intermittant then usually your brake is losing its hold. You will need a technician to do this job. It requires special tools that they should have. I repeat a technician should do this job. You can seriously hurt yourself attempting this repair. Also see if the inner tup is turning as it agitates, if it is then it i definately the brake. But one more time do not try this repair it is a dangerous repair that should be left to technicians. There is a spring that is under heavy compression that requires a tool to release it.
Dec 28, 2010 | Maytag MAV6200 Top Load Washer
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Jun 26, 2009 | Maytag Neptune Washer
My machine make too much noise
does it sound like a 747 about to crash in your house? if so you might as well through your washer away because you have a bad bearing and the cost to repair that is about the same for a new one. let me know if this helps
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
My MAH 5500B washer has a squeak when fully loaded at the start of rotation in both directions.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
if still the problem then ,Motor is kicking on and off making that far for us this has been a motor issue 9.5 times out of 10.
May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
407 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
