Question about ElektraPure EP8000 Vacuum
Elektrapure upright )red)
A plastic part in motor broke off and is lodged so the fan will
not turn .. i would like to purchase a new motor
    Novelist:
  • 137 Answers
Need to clear blower in 8850 model vacuum
Unless you have removed the plastic guard under the motor filter it is impossible for the toy to have lodged in the fan. The toy would have to go through the bag, through the motor filter and through the guard before it could reach the fan.
Mar 04, 2014 | Riccar 8955 Upright Vacuum
Oreck xl 21 fan housing has new design. willit stillfit my older vac
It should. You can call Oreck and talk with them and give them the serial number off your vacuum and they can look it up and tell you for sure if it will fit or not.
Feb 18, 2013 | Oreck Great XL21 XL 21 8 Pound Upright...
Eureka 9410 upright vacuum motor
They normally have a reverse thread nut on top then just pushed down on a tapered end so needs to be levered off normally a wide flat blade paint scraper etc can help spead load so fan doesnt break or distort
Apr 13, 2017 | Vacuums
What is causing a high pitch sound when i turn the vacuum on?
If it is causing a bad vibration as well as the loud noise than you probably broke a blade on the fan and depending on the model you might have to get a new fan housing to get the fan blade. You should check over the fan housing as well because it might have a crack or a hole in it if the fan threw a nail against it.
Nov 23, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Need bags for my elektrapure canister - part #EP1400
I have 2 packages of ElektraPure bags - #EP-1400
Mar 14, 2010 | ElektraPure Vacuums
I have a broken motor fan for the EP-1010 What is
You can get one from acevacuums.com your part # is EP-28000. If we dont have it listed just send an email to john@acevacuums.com. Let me know if you have any other questions or need any other part #s
Jan 03, 2010 | ElektraPure EP-1010 Upright Vacuum
Hoover U6317-930 - Turbine Locked Up!
You will need to remove the hood as though changing the belt. Then best to detach the handle/ bag chamber with the black screw at the lower end in the center.
Lay the vac flat and you should see two clamps over the motor housing, one on either side. Undo the clamps and the motor will lift out. There will be four more screws holding the fan shroud onto the motor housing. Remove these and detach the fan end only. Installation is the reverse order. The fan itself will unscrew if replacing,just secure the motor shaft without damaging it.
Polish the motor shaft clean for a new belt, removing burned rubber. I use 600 grit wet/dry sandpaper or steel wool.
Any evidence of a damaged fan blade means a new fan is required.
While you're at it, unscrew the end caps on the brush roll and remove the hair and thread. Then reassemble so it spins freely when holding the end caps. Install a new genuine belt. It will be snug, use the brush to pull it into place.
When reassembling be sure to engage the carpet height control through the lid
If this helps please acknowledge. If not psot back with the next problem
Oct 03, 2009 | Hoover U6311-930 Power Drive Bagged...
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Dyson won't stand upright
Hi.
If you go to the Dyson web site in there help section it shows how to sort out this problem its very easy to do.
http://dysonmanuals.llc.nu/
Jun 01, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
49 people viewed this question
Top ElektraPure Vacuums Experts
JoeVacs
Are you an ElektraPure Vacuum Expert? Answer questions, earn points and help others
