Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 will not keep blue in focus
A friend from work gave me this thing for free i just whant to see how mutch to fix the problem or if there even is one.
  • 1 more comment
  • junkhole Feb 17, 2008
    when i go into the coverage the blue + is blurry but sometimes the picture is perfect and others are unwatchable. Things that are white show up light blue and other times there is just a blue line around everything even with color all the way down everything still has blue around it.
    THANKS
  • rapidfire May 23, 2008
    my tv is a d52w20 I went into the service menu and was going to do the big convergance and the blue is just plain blured when you have it set in the right spot instead of seeing maroon or what have you you see the cross in the one color and the blue is blured around it much as if you had spray painted a blue cross and then tape a nice yellow one in the center of it can you tell is this the leek and if so where would I find the best price on the part and are there any need to know things for putting it in
  • ladywinn
    ladywinn May 11, 2010
    Need to know more about tv before anyone can say what may be wrong with your set, what kind of picture does it show and when you turn off color on menu do you have a black& white picture?
    ThankYou for using FixYa. Have a Nice Day.
    Genius:
  • 1,030 Answers
If i understand your problem...blue is out of focus.. does the blue ever in focus?...i just fixed one today at the shop with a simular problem.. is red or green sharp. do u see the blue in the outline of text on screen is the blue only in one area of the screen. it could be as simple as convergence or like the one i delt with a blue tube was leaking fluid. The leaking fluid would be bad thing,. the convergence not so bad and not as expensive. so give us a complete description and will see ehat w can do..
Posted on Feb 08, 2008
RCA 52 HDTV Triple iamges in red, blue and green
I had the same problem with my RCA D52W23. I change out the convergence board and the 2nd fuse the one near the flyback. After getting TV back together picture was good except white backgrounds looked washed out with greenest at the edges. I called cable company and they came out fixed my cable line with was dropping and gave me a new HDTV box which was the newest one. That fixed my problems.
Apr 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV won't turn on!
On the deflection board there is 3 capacitors cp150 2200uf 16v if puffed up on top it is bad so then replace other 2 capacitors as well 220uf 35v. cp114 cp120
Feb 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA SRS Focus turning on and off
the best thing you can do is take it to a shop and have it repaired as the problem has gotten worse..
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have blurry picture.
it could be in the focus control...it may be trying to go out
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 inch TV
Well done, scottyfixit!
Here's to a greener and safer environment for all!
Kudos!
IrishDruid
May 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Yes,but what your set has is poor solder connections around the Flyback Transformer.ThankYou for using FixYa. Have a Nice Day.
Jan 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture Color
http://www.partstore.com/ModelDetai...close=1&exact=1
What do you think "CRT ASSY, Projection: Blue" might be?
CRT ASSY, PROJECTION: BLUE
RCA Part Number: 258486
RCA Model: D52W20
52" CRT BLUE P16LTG00BMB, DELTA 250
They want $183,
Jan 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 60'' p60928
The set does not have a blue lamp. The set has a blue picture tube. I have found that the best RCA parts distributor is Union Electronics at 1-800-648-6657. The picture tubes in projection sets are very fragile and dangerous to handle. The new picture tube will come dry, so the lens assembly and seal will have to be assembled onto the new tube and then filled with fresh coolant. The set will then need a complete realignment, everything from screen and focus voltages, bias and drive, yoke and ring position to convergence circuits. If you have no experience in any of the above, do not attempt to replace a picture tube. Allow a qualified tech to handle it for you.
Aug 28, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
