Back to:
Tags:
Projection Televisions
Generic problem for all Projection Televisions
HITACHI REAR PROJECTION
posted by POINTMAN on Feb 08, 2008
IT WILL NOT TURN ON.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 21, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I HAVE A HITACE 50FX20D IT COMS ON BUT THE SCREEN IS BLUE OR WHITE SOMTIMS IT TURNS ON THEN TURNS OFF
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HITACHI REAR PROJECTION:
I don't want to Accept this solution
Solution #2
posted on Feb 08, 2008
Not Rated (0)
who BoB
Rank:Wiz Wiz
Rating: 82%, 53 votes
Could be blowed fuse, power supply, Horz output stage, protection mode over load, bad horizontal transformer, voltage block, broken board, burt bulb.
You will have to specified what type of PTV it is, model, and what you have done to check.
To many problem it may have, could also goes into protection do to no defflection problem.
Is it a crt rear projector, lds rear projector, dlp, plasmas, led need more info.
Regards
Bob.
Thank You!
Can you Help with these Projection Televisions problems?
power board circuit for L20V34S
Hitachi 60V500 60 in. Rear Projection...
My TV has developed a yellow spot in the center of the...
I have an Akai flat screen tv- colors on the screen look...
Just bought a new Sharp LC-32SB24U and when I hooked it up...
my zenith 36v22 picture went out but the sound still...
Loading problems.
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
