Question about Dacor ECS130 Epicure Electric Single Oven
Inside oven lights won't work.
Oven lights won't work. Would like to change lights myself. Not in instruction manual. Flipped switch but did not work.
Hey,
I went to the appliance store where I purchased the oven, and they called a Dacor representative. A flat end tool was given to me to pop out the plastic covers. There are no screws to fasten the covers, so you have to use this tool - which was not put in my kit at the time. Be careful when doing this, because the plastic cover can break. You replace the bulbs by pulling out and pushing in the socket. There is no turning the bulb. Handle the bulb with a paper towel, because the oil from your hands will take life from the bulb. Very important that the oven's breaker is off before this is done. Luckily, I had a very kind clerk helping me, and she even gave me the bulbs free of charge.
I like your website, and I will use it again in the future.
Posted on Feb 08, 2008
Miele 212 oven does not work. We have a Miele oven that does not work anymore. 220V gets to the oven and then nothing happens, no lights, no display, nothing... Advise anyone?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
May 18, 2015 | Miele Ovens
How do I get the ovens working if the clock works, but they do not?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Nov 10, 2014 | Viking VEDO205 Electric Double Oven
Oven does not heat
Apr 18, 2014 | Frigidaire Ovens
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
Ge monogram bottom oven won't clean
Follow the owner manual instructions, some condition is not set or the door switch or door lack it not operationg. Could be the monitor switch on the oven latch.
Mar 02, 2013 | Ovens
My frigidaire oven wont stop beeping and it has a f9 code
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Frigidaire FEB27S5A Electric Single Oven
OVEN WILL NOT COME ON AND IT DISPLAYS F9. WHAT DO YOU DO?
Hi
Daniel
Aug 02, 2011 | Amana AOCS3040SS Electric Single Oven
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
My electrolux premier cooker oven isnt working
Check to make sure that the circuit breaker/gfi is not flipped for the oven. Push the switch all the way to off and then on again. If the power goes off again, this indicates a short, which is very dangerous.
If you already checked this and the power does not come on, make sure the breaker is set to off and pull the oven and check the cord and plug for any sign of fraying, loose wires, blacked areas, etc.
Since this is 240v, I would not recommend going beyond these basic instructions. If you feel confident to remove the panel to run some electrical tests, please post comments and we will help you do that.
May 09, 2010 | Frigidaire 30 in. Electric Gallery Series...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Dacor ECS130 Epicure Electric Single Oven Logo
289 people viewed this question
Top Dacor Ovens Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Jose Pino
Are you a Dacor Oven Expert? Answer questions, earn points and help others
