Question about Gateway FPD2275W LCD Monitor
Westinghouse LCD monitor
The screen is starting to flicker.
  • Anonymous Sep 01, 2008
    Westinghouse LCD TV cable connection for TV, started to flicker one in a while now flickering 90% of the time.. after 3 months.
  • 44 Answers
Flicker to which side, horizontaly or verticaly. does it compress from both side or all side. only flicker from sides or from the center also??????????
provide proper information for solution
Posted on Feb 08, 2008
SK-32H240S
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jul 28, 2014 | Westinghouse Televison & Video
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
No power Westinghouse LD4655BX
- Flickering screen
- Dim screen
- Slow start
Apr 04, 2014 | Westinghouse Televison & Video
Dotted lines across the top of the screen and flicker in other video ports.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 05, 2017 | Westinghouse LVM-42w2 Television
Goes blinky
Hey there.
I have recently written a tip on the Flickering/unstable LCD/CRT monitor screen problem. I suggest you give it a read and let me know how it goes.
You can see my tip here: http://www.fixya.com/support/r9423506-flickering_lcd_crt_monitor_screen_or
Enjoy my tip.
Slasher_X
Sep 23, 2011 | Westinghouse L2046NV Monitor
Screen Flickers and won"t stay on. what is causing
Please read here:
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 16, 2011 | Westinghouse L1975NW Monitor
Screen goes black with power on. It also flickers and power flickers. Does both randomly. New computer. All new drivers. Windows 7. Video card and monitor set with same display settings.
This sounds like a power issue. Check the power cord going to the monitor. Make sure it is fully plugged in. Make sure the receptacle is good and the wiring at that receptacle is tight and secure. Try another receptacle to be sure. Make sure the cord going from the computer to the monitor is secure and tight. You say this is a new computer. If so, then take it back where you bought it if you cannot find the problem.
Dec 12, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Flickering white bars scrolling down my lcd monitor screen
Have you tryed unpluging then pluging your video cables? or something?
Aug 28, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Flickering/pixelating screen on LTV-27w6 HD after 30 minutes.
Sound like dry goint on Power Supply bord. I had the same problem and resolder most of the parts of the power supply and TV was ok.
Dec 22, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Gateway FPD2275W LCD Monitor Logo
125 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
