Question about HP Compaq FS7600e CRT Monitor
Compaq Monitor FS7600e - 17" monitoor
Hi my monitor is almost 16 months old now.. Yday while working the screen went white.
I shut down the pc and restarted.. Now its showing black only.. Nothing is visible on the monitor even though the hard disc seems to be working.. Checked the cable connections and they seems to be okay.. Is there anything I can do myself ?
Thanks and regards
Anand
  • krianand Feb 09, 2008
    Hi Thanks a lot for the help. But I am not sure how to do this.. But when I connect my monitor to my laptop, it shows fine.. But wouldn't work with desktop.. Is this problem in my hard disc which is whirring and i can hear the noise as if its working fine.
    Thanks and regards
    anand
  • 44 Answers
The -ve ground voltage decreased when u saw the screen goes white.if it flash too much then may be the front phosphorus coating burn due to excess whiteness suddenly. if that is ok then check the the G1 voltage , they are in excess, follow the track and replace the components after checking. also check the heater voltage and screen voltage (G2) ( do not touch the G2 voltage without insulation. they must be between 500-1000 volts. if they are disappears then check the EHT transformer. if the problem still prisist then inform me, i will guide u step by step.
Posted on Feb 08, 2008
  • Inderjeet Singh Bhambra
    U said it's working with ur laptop not with ur desktop machine.
    so tell me when u attach it to ur desktop machine, what are the symptoms it shows. when u on your monitor without attaching anywhere does it shoes the raster in starting then goes into power safe mode or directly goes to power safe mode. when u attach the desktop machine is the power led start blinking. if yes then please check the desktop machine refresh rate controlled by display card, also check the other monitor on that machine, is it working, if yes. then decrease the resolution and refresh rate to minimum and back on. if u don't have the another moniter then u can set it in safe mode by restarting your computer and keep pressing f8 key. if problem still prisist then inform me, there r so many wayes... best of luck...
Compaq Evo N600c Laptop over 5 years old but has been working fine. About 2 months ago the screen went dark (bad lamp?) so been using an external monitor. Turned it on this morning and it started to boot...
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
Feb 25, 2011 | Compaq Evo N600C PC Notebook
I have a computer monitor that has suddenly gone to a black screen with this note: "out of frequency range set resolution lower or see monitor instruction manual. How do I do this if the screen is black?
if you have a video card in your PC shut down, remove the card and this should do it, if you want to install the card again, shut down re-install card, and it should also work
Dec 29, 2009 | Compaq CV 7500 (Carbon, Silver) 17 in.CRT...
Removing anti virus xp 2008
try and system restore your computer to an earlier date when you knew your computer didnt have it installed
Aug 27, 2008 | Compaq fs740 17" CRT Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
"BLANK SCREEN, CLICKING SOUND, & NO LED INDICATED".
some electronic components on the circuit was shorted.
clicking indicates this type of problems.
Dec 03, 2007 | Compaq FS7600 17" Flat Glass Monitor
Screen colors
possibly screen color depth is set to 16 colors. - open control panel display - settings tab, slide the color depth to 16 bit. - change resolution to 800 x 600 for now. reboot and see if that does the trick, then readjust settings to your tastes.
Aug 26, 2007 | Compaq CV 7500 17" CRT Monitor
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
HP Compaq FS7600e CRT Monitor Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
