I
have a Dell 1545 with Dell web cam central & I've had this issue.
The problem is that Dell web cam central installs it's own microphone
settings onto your laptop called something like Dell web cam Live!. This
isn't the built in microphone in my laptop & maybe not yours
either. You have to change the settings for your computer system &
Dell web cam central. Go to start> control panel> sound>
recording .. on mine there is an option for Microphone "High Definition
Audio Device" ... that is the built in mic. You want that for your
default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the
"Record Video's" option. In the middle of this is an orange button with a
video camera icon. Next to this on the same button is a little arrow
pointing down .. click that. Under microphone .. choose Microphone "High
Definition Audio Device" just like the sound option in control panel.
I've done this & it's completely fixed. I can record videos with
sound & use my built in mic in voice/video chat.
make sure the mic jack is not in the speaker jack please try swap it. if it does not work, plug the mic and go to control panel select sound devices there u can set ur mic, if not reinstall ur sound driver, thanks, dont forget to vote me if it works
You will need to go into your sound properties, you can do this by clicking on the speaker Icon thats down by the clock (lower rights hand side of your screen) that should bring up sliders for everything. Their is also other options and advanced options you may need to enable that could be specific to your devices. but the main thing here would be for you to disable the one mic and enable the one you want and also possibly lower its sensitivity levels.
Video camera has built in microphone which is on at all time until you plug in different type of mic then camera is switched to new mic. Audio problem may be on audio head or circuit problem. You can test the system by playing pre-recorded tape to see if it play with the sound and go from there. If it play but does not record sound, you have audio recording problem. If it does not play, I would clean the video head and audio head area good. -James For further assistance, request help at www.camerarepairjapan.com
Normally every Lap is coming wit internal mic; so 1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings. ** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills. Thank you & Best Regards Dinu..
Is your microphone integrated into your webcam? Make sure the correct device is selected. Go into Edit, Settings, Enhanced IM. Under Audio and Video, make sure the Microphone device selected is a functioning mic, such as Logitech Mic, or if using a headset, select the USB headset (if usb) or your sound card if using a mic plugged into your built in or add-on sound card.
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
un cheak must plug it in or unplug it from mic input and plug back in tight cheak again might be bad mic then u could get a 10 doler one plug back in mic hole use cam for video only
