Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
Open the side
I removed the two screws and pressed down on the small lever and the side panel will not move.
How do I open my computer
  • 1 more comment
  • Bad Axe Feb 08, 2008
    Sorry, I thought I put that info in there.
    The computer is an ACER Aspire E380
  • Bad Axe Feb 11, 2008
    Someone else finally advised me that the side panel was probably just stuck and needed a little more effort to slide out.
    They were right and it worked.
    Now my speakers don't work after I plugged them back in.
    Any solutions for that?
    Thanks for trying. This has happened before when i unplug the speakers. There are no instructions that tell me what settings are required to make them work.
    I'll probably have to take the computer back to the store and let the GEEK SQUAD tell me what needs to be done.
    Trust me when I say I am not totally ingnorant. I can read and follow instructions when they are provided.
    If you think I'm unhappy with ACER, you are right. Never again.
  • 92 Answers
What kind of a pc is it ?
Posted on Feb 08, 2008
  • Andrew Thompson
    Andrew Thompson Feb 11, 2008
    Open it back up and check the front panel wires to see if they are all plugged in, and if plugged in to check if there plugged in correctly
    The speaker's front panel wire has a is hard to miss ! it usually is the widest of the wires and it's also usually marked speaker with a 4 pin female connector. hope this helps.
    let me know
How do I removed the tailgate door liner panel on a 2005 Suzuki Grand Vitara JB?? There is no inner door latch to be removed. We cannot open the rear door as outer handle has broken. Help....many thx
The top bezel pops off. There are usually 2 screws to remove from the top of the bottom bezel on each side. start popping the bottom bezel off the hatch. It won't come out. Screws on the bottom. But you can get if off enough to reach down and grab the latch rod or latch to release the hatch. Yes the latch is at the bottom. And it has levers to move to open the hatch. Once open, remove the screws to remove the bezel, then replace the latch.
Jan 05, 2017 | Suzuki Cars & Trucks
Driver side window does not always open can this be fixed by me or do I need a mechanic
It sounds like you have a bad connection or window switch is bad if you can remove the door panel you can probably replace the switch yourself without taking it to a shop
Mar 23, 2015 | 2005 Ford Focus
Get into neutral w dead battery
on console, there is a small plug, by shift lever ,or close by it, with a small flat blade screw driver, open it, putting finger in and pressing down, this will let the shift lever, move to neutral
Dec 08, 2013 | Scion Cars & Trucks
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
How to open gateway 300c desktop
There are several casings. You'll just have to pick one that fits your computer. Before you begin anything. Turn off your computer and remove the power cable. New Midtower Case 1 Look for a release handle on the top of the new midtower case. 2 Push the release handle inward. 3 Swing the case down from the top to open it. Microtower Case 1 Lay the computer down so that the left side is face up. 2 Locate two cover release levers on the back of the case toward the middle of the left side panel. 3 Squeeze the release levers together, then lift the panel up, swinging it away from the back of the case. Old Midtower Case 1 Lay the computer on its side, so that the left side panel is face up. 2 Remove any retaining screws along the left side of the back of the case that are holding the panel in place. These screws may be removed with your fingers. 3 Locate two release levers at the top and bottom of the back side of the case, and push them away from each other. 5 Swing the panel up and away from the case to open it while holding the release levers.
Jan 01, 2011 | Gateway 300 C PC Desktop
The rear hatch seem to be jammed or stuck it wont open at all how can i get it open
Crawl thru the front to the rear of the truck, Remove the two screws on the gate release handle (they are underneath the handle, two philips).
Gently pull on the plastic panel by the release handle, it will come out about 4 inches, it should be enough if you have a small arm (which I have.) I wedged a plastic 20oz bottle between the rear gate and the inner plastic panel, to keep the plastic held out, don't over stress the plastic it will break if its old enough, look down from the window hatch about 5 inches or so and notice the 2" x 3" opening, there is a lever in there that is moved by the actuator, and a piece of plastic (which is what my friends truck needs, if someone has a part number or aftermarket please advise) but if you reach in to that access panel, there is a slide that moves from right (looking at the gate from the inside) to left, moving it to the left (Opens the window)
Apon opening the window, remove the plastic bottle, and open the rear gate hatch, when the hatch is open there are two screws one on the left side of the gate, and on the right side.I hope this helps you out, remember: don't overstress the plastic, strip out the screws, or break the window..
Once you have everything out, you can replace the actuator or fix the wire leads that may have come loose form the rear door actuator keep you from opening the rear window.
Good luck and thank you for using fixya
Mar 06, 2010 | 2001 Chevrolet Blazer
The tapes In my Panasonic PV-GS14 are stuck and won't run
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
May 09, 2017 | Panasonic Palmcorder PV-GS14 Mini DV...
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Oct 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Want to open my maxtor one touch, any idea of the best way, and what is that small openning at the back
It's a pain but you can do it if you are careful. Remove 2 screws on back panel, then gently remove back panel. Now work on side/front panel (one piece) GENTLY. They have little plastic clips that will pop out if you are careful. The you can remove 2 more screws on side that hold metal halves together. Top comes of clamshell style. Good luck !
Mar 30, 2008 | Maxtor OneTouch II external hard drive...
Cover open
Cannot print due to cover open displays in window
Nov 19, 2007 | Lexmark X5250 All-In-One InkJet Printer
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
