Question about Toshiba Satellite M115-S1061 Notebook
Network Problem (cont)
Well your first "solution" didn't work. I encountered this error:
"An error has occurred while renewing interface Local Area Connection 2: The RPC server is unavailable."
  • Anonymous Mar 17, 2014
    rpc server is unavailable
    President:
  • 778 Answers
What first solution and who posted it, I would suggest containing your issue to the original thread instead of starting a new one. You will get better results if you do so.
Good luck.
Posted on Feb 24, 2008
On boot, i get the error "Device monitor
Try reinstalling it. It may just be a problem encountered in the installation
Jan 24, 2011 | Lexmark X4975 3-in-1 Wireless Inkjet...
Cant connect to my wireless router and the 192.168.01 url entered doesnt help none
Windows XP
  1. Verify Ethernet adapter in device manger.
    1. Click Start > Search > Type in ncpa.cpl and press Enter.
    2. Click System>Hardware > Device Manager
    3. Click Network Adapters
    4. Verify adapter present, enabled, and no error messages.
    5. If error reported refer to OEM regarding error receiving
  2. Open the Network Connections window.
    1. Click on Start > Run > Type in ncpa.cpl and click OK.
  3. Double-click on the Local Area Connection icon.
  4. Click the Support tab.
    1. Ensure that Address Type: says "Assigned by DHCP."
    2. Ensure that the IP address is valid.
    3. If both are correct, click the Repair button and then skip to Step 9.
  5. If it does not say "Assigned by DHCP" click the General tab and then click Properties.
  6. Select "Internet Protocol TCP/IP" and then click on the Properties button.
  7. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  8. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations.
  9. Right-click on Local Area Connection and select Repair.
  10. If the repair fails because the system is unable to flush the ARP Cache, the Routing and Remote Access service will need to be stopped and set to disabled.
    1. Click Start>Run>Type services.msc >Click OK.
    2. Double-click on Routing and Remote Access.
    3. Click the Stop button.
    4. Set Startup Type to Disabled and click Apply, then OK.
    5. Restart system.
  11. If the Repair fails to renew the IP address, ensure that all firewalls are disabled and try again.
  12. If it still fails, reset the networking protocols.
    1. Click Start>Run>Type CMD and click OK.
    2. Type netsh int ip reset reset.log and press Enter.
    3. Type netsh int ip delete arpcache and press Enter.
    4. Type netsh winsock reset and press Enter. (SP 2 or later)
    5. Type ipconfig /flushdns and press Enter.
    6. Restart the system.
Windows Vista
    2. Click Hardware and Sound > Device Manager
  2. Open the manage Network Connections window.
  3. Right-click on Local Area Connection and select Properties.
  4. Uncheck Internet Protocol Version 6 (TCP/IPv6).
  5. Select "Internet Protocol Version 4 (TCP/IPv4)" and then click on the Properties button. (Do Not Uncheck Version 4).
  6. Ensure that the radio buttons are marked as "Obtain an IP Address automatically" and "Obtain a DNS Server address automatically" and click OK.
  7. Click OK again to close out of the Local Area Connection properties.
    1. Restart the system if any changes were made to the configurations, including unchecking TCP/IPv6.
  8. Right-click on Local Area Connection and select Diagnose.
  9. If Diagnose fails to renew the IP address, ensure that all firewalls are disabled and try again.
  10. If it fails again, choose to "Reset the Network Adapter."
  11. If it still fails, reset the networking protocols.
    1. Click Start>All Programs>Accessories.
    2. Right-click on Command Prompt and select "Run As Administrator"
    3. Type netsh int ip reset reset.log and press Enter.
    4. Type netsh int ip delete arpcache and press Enter.
    5. Type netsh winsock reset and press Enter.
    6. Type ipconfig /flushdns and press Enter.
    7. Restart the system.
Windows 7
I hope this helps
Oct 01, 2010 | Computers & Internet
What is a local Area connection? My laptop doesn't work, but my desktop does?
Local area connection is the wired network interface card on the computer. On a laptop you'll see the port on the side or back. If you have a internet cable conencted to the port you'll be able to access internet on a wired conenction. Most likely you are conencted wirelessly on the laptop so it shows the local area connection disconnected.
Jul 28, 2009 | Computers & Internet
Internet problem with the Lenovo Y450
I have had this problem on the Lenovo, before. Go to Network Connections, then Advanced, then Advanced Settings ...
Next, use the Adapters and Bindings tab. Look in the Connections window (the first window). Select "Local Area Connection". Push up arrow until this is placed at the top of the list! This makes the network pay attention to the Local Area Connection, first.
Then use the right click on the Network Icon (in Network Connections) to Repair the connection.
If you have a wireless connection, you may temporarily change this to Disabled.
Lenovo also has an "Access Connections" utility, called ACMainGUI.exe. This will do some network diagnostics for you.
It is important to use the correct Network Interface on the Lenovo. Otherwise, the Lenovo will think that you have no Network interface!
Jul 04, 2009 | Lenovo IdeaPad Y430-3231U Notebook
Network connection problem - need to repair "IP address"? Several weeks ago my computer stopped working, we thought it was the internet since it was a week after we got DSL (but it was working for a...
Run the winsock fix. If you don't have it, try: http://winsockfix.en.softonic.com/download#pathbar This is a direct link so it may not start automatically, but just click on the "click here" button. Good luck.
Jun 13, 2009 | Computers & Internet
No internet connection,
hi
if you have already configure your router and it was working following thing could have happen
1) you have lost connection to internet ...go to your router setup page under status make sure you have connection
2) once you have your router connected re-boot your laptop or pc or renew your wirless connection
good luck
Jun 12, 2009 | Linksys WRT54G2 Wireless Router
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
Fuji f700 memory card full error
Simple fix... go into the setup mode and scroll down to Frame No. option and change from Cont. to Renew by touching the right scroll button. After that exit/save the changes and it will then work again. However, I put mine back on Cont. and all was just as it had been prior to having that problem. It may be some internal counter that simply runs out possible, thus Renew will reset/repoint the counter, and after that you can change it back and it will again name files continuously which I find most helpful.
Hope it is helpful for you.
Feb 08, 2009 | Fujitsu Cameras
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
LAN connection constantly disconnects
Please check with the Internet provider,there is an bug occouring with the exchange server.
Try to put another modem, if you are having the same problem,then it is the your service provider problem.
If no problem try to check the software setting with the first modem.
Regards
Jan 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Toshiba Satellite M115-S1061 Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
