Question about Samsung HL-R6167W 61" HDTV
56 inch Samsung TV
When facing the TV I see aline about 2 inches wide (OR LESS) shadow. Only when the TV is on. I just had the lamp and ballast replaced because the TV kept shutting down. $576.00 later I am now experiencing this new problem.
CALLING SAMSUNG CUSTOMER SERVICE IS A WASTE OF TIME.
Any suggestion?
  • 113 Answers
This shadow is called by the light tunnel in your optical engine. You can have someone come out and try to fix the light engine. I am an authorized samsung tech and about 80 percent of the time I can rebuild the light tunnel. If the tech can not fix the light tunnel you would have to have the optical engine replaced. The light tunnel is something you would not want to attempt yourself. At least you can explain to a shop what your problem is..if they have not heard of this call a diffrent shop.
Posted on Feb 08, 2008
I have 6-8 inch horizontal shadow at the top of my HL-R5078W. How can I get rid of it?
A darkened band on this model is almost a certain bad optical light engine--not much else can even cause this.
Jun 16, 2012 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung 50 inch tv blew last night burning smell at time not getting any picture just a clicking sound
It sounds like either the lamp has blown or the ballast for the lamp has blown. You can call 1-800-samsung for nearest service center.
Feb 23, 2010 | Samsung DLP HL-P5663W 56" TV
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
Feb 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
3 problems 1. TV shuts off and on automatically. 2. 2 inch band on left side of screen 3. No picture at all
The band or shadow on the left side of the screen definitely sounds like a defective light tunnel.As for the intermittent pix and shut down this could be the lamp if you have not already changed it.
Oct 15, 2009 | Samsung DLP HL-P5663W 56" TV
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
I have a 56 inch JVC HD TV model# HD-56G647. yesterday when I turned the set on there was a black shadow in the lower hand corner. today it's bigger. i called jvc and they told me to make sure the...
Red light lamp indicator is blicking on my 56 inch mode;# 56G647 tv and the Tv screen is black with no vision of tv and no sound. What sould I do
Oct 17, 2008 | JVC Televison & Video
Samsung dlp tv
Yes, it could. There is a light pipe in the light path that could now be broken from the bumping or it could just be out of line from the bumping. Another problem could be the mirrors in the projection path could just need adjusted by the 3 screws that are beside the mirrors. This may also happen when bumped.
Mar 20, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Two inch shadow on tv
Change the input to AV1 or AV2 with no signal and see if it's still there, if it is you might have a defective light engine in which a lot of manufacturers will warranty. This can be repaired in the home but some shops preferr to take them in, try for the in home co's first. Just a word to the wise, DLP's do not last as long as you may want.
Mar 19, 2008 | Televison & Video
Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Jan 16, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6167W 61" HDTV Logo
206 people viewed this question
Jerry Greenberg
Jerry Greenberg
