Question about Panasonic Workio DP-2330 Printer
Brush roller lines in feed direction of pages
I am getting a brushed roller pattern in the feed direction of the page, with a white page on the doc glass. I replaced the drum; blade, and developer. Now I am getting the same copy quality issue, but lighter. Transfer, or charging roller?
    Problem Solver:
  • 19 Answers
Maybe the charge roller. Make sure it is very clean. You can also stop a copy before it enters the fuser to rule the fuser rollers out.
Posted on Feb 08, 2008
Brushes will not turn
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?page=3&q=bissell&type=product
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 17, 2014 | Bissell 9200 Upright Vacuum
Replace photo conductor
Charge roller and charge roller brush must be cleaned and the cleaning blade should also be cleaned. I the copy was made through the doc feeder then your optics are dirty. Take a damp cloth and clean the slit glass and exposure glass.
Jan 24, 2014 | Gestetner DSm415 All-In-One Laser Printer
On my HP C5280 a small rectangular stick-on brush became dislodged during the feeding or printing and was stuck to the left hand side of my printed page. It now prints the jobs crooked to the page. I've...
yeah,
Open the cover of printer check the tonner move the cover of printer,you'll see the green roller, check whether any stuck around it roll it forcefully (dont break it) clean perfectly,anything must be stuck there,
when you feed paper, check aroud paper pick roller and left and right side of it,is anything stuck there.
just try it out.
Mar 04, 2011 | HP Photosmart C5280 Printer
Getting a dark line on the copy pages. Need a new
Mite be a problem with your doc feeder. Are you using a doc feeder? If so raise up the doc feeder and place an orgnial on the big glass instead of feeding the orginal thur the docfeeder. Does the line disappear? If it does then the **** glass the small glass used by the docfeeder has a mark on it or dirt. Is your machine a printer also? Does the print have the mark/line on them also. Do any of your machine's internal reports have line on them Meter Read print outs etc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 25, 2010 | Kyocera Mita Office Equipment & Supplies
Bottom wheel won't turn and belt is on
When a Dyson DC07 roller brush does not spin, it can only be caused by one of two problems.
The Dyson DC07 uprights use a clutch mechanism to control the brush spinning when you change the floor / carpet switch. When the brush doesn't spin, it's caused either by the clutch or roller brush gone bad. Most other uprights use a belt to spin the roller brush, and if something is stuck in the roller brush it will cause the belt to break. Dyson vacuums however will make that awful grinding noise rather then breaking the belt.
I'll be happy to walk you through step by step on how to diagnosis this problem and find out which one of these two parts is bad on your vacuum.
Step 1. Make sure the vacuum is unplugged. Then turn the vacuum upside down so that the brushes are facing up. It's easiest if you put the head of the vacuum on top of a bench, or counter top. This is how the vacuum should look:
Step 2. You see on the bottom of the vacuum 3 plastic screws that are usually the same color as the vacuum cleaner. If you're vacuum is purple, the screws will also be purple. Use a flat head screwdriver, and turn each of the 3 screws a half of a turn, counter clockwise to loosen then. After each screw has been turned (you don't need to remove the completely, just a half of a turn is all), simply pull upwards on the bottom plate to remove it.
Step 3. You should now be able to see the roller brush exposed. You'll now need to remove the roller brush. This will take some patience, and some work in order to get this brush out of the vacuum. There is a special tool that has been designed to help you get the brush out easier. I would try getting the brush out first before buying this special tool. The easiest way is to use a flat head screw driver and pry the belt up while pulling up and out on the brush. With some patience and some maneuvering, you'll be able to get the brush out of the vacuum. Here's where you should put the flat head screw driver on the brush:
Step 4. Once you get the brush out of the vacuum cleaner, it's time to test it. Use your finger tips to hold just the end caps on the very end of the roller brush. While holding just the end caps, use your thumbs to try and spin the roller brush. Does the brush spin freely? It should rotate completely several times on each spin. If the brush doesn't spin, or you feel some kind of resistance to the brush spinning, then this indicates that your roller brush has gone bad. Here's a picture of how to test the brush:
If the roller brush went bad, then you'll need to purchase a new one. Here's a direct link to the roller brush your machine uses on our website GoVacuum.com:
http://www.govacuum.com/dysondc07.html
If the brush however was able to spin freely, and it spun multiple times on each spin, this indicates a little more serious problem of the clutch itself has gone bad. The clutch replacement repair is a much longer, more challenging repair to do. There is a very helpful video on how to replace the clutch below so that you may follow step by step instructions on how to change it. It was really helpful for me the first time I did this repair.
If you need to replace the clutch, here's a direct link to the clutch your Dyson DC07 uses on our website:
http://www.govacuum.com/dydcclasfore.html
Here's the video on how to replace the clutch:
When the brush stops spinning it can only be one of these two problems. This clutch mechanism was so problematic that Dyson removed it on the second series of the DC07 models. I hope that this repair was helpful in diagnosing your problem. If you have any questions about the diagnosing, or the clutch change, please feel free to use the Clarification Request form here on the Fixya repair page. If this was helpful you, please be sure to rate my repair as helpful by clicking the thumbs up icons.
Thank you,
Chris J.
GoVacuum
Apr 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kyocera fs 4000 how to replace drum, transfer roller and pickup roller
(1) Detaching and refitting the drum unit
Procedure
1. Remove the developer unit (See page P.1-5-
9).
2. Open the left side cover and then remove
the waste toner box.
3. Unlock the drum unit lock and then remove
the drum unit.
4. Check or replace the drum unit and refit all
the removed parts
(1) Detaching and refitting the transfer roller and separation charger brush unit
Procedure
9).
2. Remove the drum unit (See page P.1-5-10).
3. Slide the paper chute guide and unhook the
hooks.
4. Remove the paper chute guide.
5. Remove the shaft (transfer roller) from the
both bushes.
6. Release the four latches and then remove
the separation charger brush unit.
7. Check or replace the transfer roller and separation
charger brush unit and refit all the
removed parts.
CAUTION: Note the following, when refitting
A. The separation charger brush unit is
inserted into the two projections of the frame
and does not run on to the projections.
B. The separation charger brush unit is
firmly in contact with the separation charger
plate of the frame.
(1) Detaching and refitting the paper feed assembly (paper feed roller and pickup roller)
Procedure
1. Remove the paper cassette.
2. While pushing the lock and then slide the
paper feed roller pin.
3. While pressing the lever and then remove
the paper feed roller assembly.
4. Check or replace the paper feed assembly
and refit all the removed parts.
(2) Detaching and refitting the ****** roller
Procedure
2. Push the bottom plate down until it locks
(30/31 ppm printer [EUR/USA model] only).
3. Unlatch the two latches and then remove
the ****** guide.
4. Remove the ****** holder (roller) from the
****** guide.
5. Check or replace the ****** roller and refit all
the removed parts.
Feb 04, 2010 | Kyocera FS-4000DN Laser Printer
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Doc Feed Problem
I would replace the Pick-up roller, Feed Belt, Sepearation roller, and torx Limiter for starters IF you cannot replace them, Clean them with warm water and soap, let them dry, and try the doc feeder, Most Multi feed problems are Torx limiter or clutch problems.
Apr 11, 2009 | Office Equipment & Supplies
Dyson o7 animal pick up problems
Hi.
If your machine is A few years old it may need new brush roller fitted.
To check roller for wear lie machine on the floor & pull back head end as if vaccuming carpet.
Now get A rule or straight edge hold this over brush roller & sole plate oppening.
Now rotate brush slowly by hand the bristles of the brush should just kiss the edge of rule. If ther is a gap you will need toreplace the roller.
http://dysonmanuals.llc.nu/
Jan 11, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Panasonic Workio DP-2330 Printer Logo
103 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
