Leaking aircon I have a carrier air con which is leaking into the room. It is 13+ years old. It has a 10 amp line but adequately cools a 31 square metre room. I am happy to replace it but do not know what btu it is. How can I find out.
  • jc169363 Feb 08, 2008
    Alternatively anyone have any ideas how to stop the leak which floods the room each time it is used. It does not have a drain in the back.
  • cristiansara Feb 28, 2009
    we have a carrier aircon too.  it was given to us second hand and was only 5 years old when we got it, its only been giving us grief the last few days, we have been having a really really humid spell and changed it over to the humid setting, then viola! water dripping all over the new carpet! joy!
    we dont have a manual, but the unit is high on the wall and the outer unit is outside on the ground.  help! id rather be spending money on fixing my fence than this damn airconditioner.
    Novelist:
  • 114 Answers
THERE IS A TUBE OR CHANEL FROM THE FRONT EVAPORATOR DRAIN PAN THAT RUNS TO THE BACK OF THE UNIT INTO THE CONDENSER PAN. IT IS ALWAYS ADVISABLE TO THOUROUGH LY CLEAN ALL COILS, AND DRAIN PANS AND DRAIN LINES ANUALLY. IF THAT TUBE OR CHANEL WAY GETS PLUGGED IT WILL CONSTANTLY DRIP IN THE COOL MODE.,
IF YOUR A/C IS 110V MOST ALL ARE ABOUT 5,000 - 7,000 BTU''S ALL SHOULD RUN ON A SEPERATE CIRCUIT OR NOT HAVE ANYTHING ELES PLUGED IN ON THAT CIRCUIT.
MOST ALL WINDOW UNITS HAVE THE BTU'S RATING ON THE TAG INSIDE THE UNIT. THESE SMALL UNITS REQUIRE COMPLETE REMOVAL FROM THE WINDOW OR WALL FOR CLEANING. ONLY LARGER UNITS 10,000 AND ABOVE SLIDE OUT OF THE CABINENT FROM THE FRONT.
90% OF A/C I HAVE REPAIRED IN 40+ YEARS WERE DUE TO PLUGGED DRAIN LINES A DIRTY COILS. THEY MUST BE ALL CLEAN BEFORE I COULD START TO DIAGNOSE ANY PROBLEM BECAUSE THE PRESSURES VARY IF THE COILS ARE RESTRICTED WITH DIRT, ETC.
Posted on Feb 08, 2008
Ther is no drtain in the back !!! The water that drains to the back drains into a pan below the condenser coil wher the "Slinger-Ring" around the rear fan blade picks up the water and sprays it on the hot coil outside to help cool-it down.
Posted on Feb 09, 2008
WHERE IS THE DRAIN FOR MODEL 52CEC309351AA
Find the drain outlet and use a wet vacuum on the drain line to pull gunk clogging the drain line out. You may need to reclean on more periodic basis. Problems with drain line gunk buildup vary with location airborn contaminants. Your water leaking could also be not a drain problem, but an air leakage by the seals in the unit installation. If unit is not sealed properly, warm moist air can leak in past bad or missing seals and come in contact with cool surfaces and condense water out and leak out of unit.
Hope this helps
Oct 21, 2014 | Carrier Heating & Cooling
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
WATER COMING THROUG FRONT OF FUJITSU fan coil unit
vent pipes are not sealed properly and condensation is building up and leaking out .
Jun 10, 2017 | Fujitsu 12RLS Halycon Wall Mounted Air...
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
How much horsepower of aircon do i need for 20sq m space of area?
IIT DEPEND ON HOW MUCH COOL DO YOU LIKE 5,000 B.T.U. WILL COOL A SMALL ROOM BUT AN 8,000 WILL KEEP IT COOL.
Nov 26, 2009 | Samsung Heating & Cooling
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
Panasonic CS-12JKZW aircon leaking water.
get a air condtioning tech to do it.high voltage in side the unit.plaes call the service center of panasonice agent.
Jun 08, 2009 | Panasonic Room Air Conditioner CWXC104HU
Heating & Cooling Logo
986 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
