Question about HP Pavilion dv6000z Notebook
FREEZES I have a PD dv6000. It takes my computer a long time to boot up but then it freezes on the log in screen after a blue screen with 'Checking file system on drive D... type of file FAT32...'. I did a restore, but that didn't help.
    Genius:
  • 1,226 Answers
Hello:
There are some application that is annoying to your computer. The symptoms of the blue screen, is when there is new application installed, new hardware, bad memory, bad HDD, and the worse is bad motherboard.
However you can resolve the problem if there is no problem on hardware. By reformatting and reinstalling the windows.( Note: reformatting and reinstalling the windows will remove your important files in it.)
Of course after reinstallation, You should install all the driver utilites of your stuff.
If the solution above doesn't solve the problems. Please examine the memory and the hard drive.
May this help, Best regards, melnavz.
Posted on Feb 08, 2008
When I log on it goes to the window screen and freezes up
Restart your computer, as it's restarting press f8 a boot up menu should pop up, among the options in that menu you'll see last known good configuration, select it, you're computer should hopefully start up normally, if it does not you may need to reformat, or take it into a tech shop for assistance.
Feb 13, 2013 | Dell Inspiron 8500 Notebook
My 21" mid 2007 imac periodically freezes, the
Try booting it into single-user mode holding down Command(Apple) and S buttons when powering up. Then in terminal console, use chkdsk -fy. Use it and use it again until comes back with something like "Volume appears to be OK". Then use command: mount -uw / and then type reboot and try booting normally.
If it does not fix your problem, it's most likely a hardware issue (logic board / graphics card), and you should take it to an Apple Authorized Service Provider.
-juuko
Nov 08, 2010 | Apple 24" iMac Desktop
My Computer will turn on and go to the windows XP loading screen with the blue bars and will won't load up, it rarely does but when it gets to the log on user screen it freezes
Right after your POST screen goes off,before you get to Windows starting,try pushing the F8 key several times until you get the Windows boot options.Then try 'last known good configuration".
If that doesn't work,you can boot from the Windows installation disk and try to repair your Windows installation.Let me know what happens.
And good or bad, please rate my post?
Bob
Aug 11, 2010 | Dell Microsoft Windows XP Home Edition
Why do i have to reboot 4 or 5 times to get it to work?
This is probably done to the bios on start up you will need to load new bios when you get connected
May 09, 2010 | Acer Aspire One PC Notebook
Screen freezes on start up power off,power on freezes again .whats the problem ?
Hi ,
This happens when a startup program is is corrupt or is not responding.It can also be that a hardware is gone corrupt that is making the computer freeze.To correct the problem please follow the trobleshooting steps listed below.
Disconnet any external devices that you have added after you bought the notebook like usb devices ,printer etc.Then turn the computer on and see if the computer freezes or not .If it does not freeze then it means that there is an external device that is causing the problem and to find it out you need to connect one device at a time and check .
U can also do this .Turn the computer off completely and then when you turn the computer on keep on tapping the F8 key till it loads the advance boot menu page then select safe mode just plain safe mode and hit the enter key .Wait till it loads the the log on screen then select administrator.It will take you to the desktop and check if the computer freezes or not .If it doesn't then it means that there is a program that is causing the computer to freeze.Go to start?run ?type in msconfig?enter?click on the startup tab ?click on disable all?apply ?select the services tab?click on disable all ?apply ?click on ok or close to exit from the page and then select restart when it prompts you to .When it is booting up to the normal mode check if the computer freezes.Then you will have to find the program that is causing the computer to freeze.To do this first enable all the startup program and then check if it doesnt then its a program under services that is corrupt .S o select one or more program restart and check so this way you will have to isolate the program and then just leave that program unchecked.
Hope this post helps you ...all the best
you can revert if this does not work....
May 08, 2010 | Medion MD-40954 Notebook
I cant get my computer to fully boot up
This might happen if you install McAfee with applications running, or not restarting Windows, etc. I am not sure why you couldn't boot in Safemode, booting in safemode is exactly what you need to do to uninstall McAfee.
Mar 13, 2010 | Acer Aspire M5641 PC Desktop
Freezes after logging in
It's time to reinstall the operating system--you have had a virus destroy the boot/load sector, thus the lag.
Apr 11, 2009 | Dell Inspiron E1505 Notebook
Computer turns off then on after first boot
2 beeps is memory issues.  Either your RAM is bad or the Video card is bad.  If you are getting the BSOD, blue screen of death, then I would take out all your RAM and start it up with a single stick, so you can find out what stick is bad.  If you only have 1 stick, replace it.  I say to do the memory first, because it is the cheaper fix.
Mar 12, 2009 | Soyo P4VTE (SY-P4VTE) Motherboard
Unable to open mail
You could try going to your Tool Bar and choosing Internet Options. Then change whatever address is in your homepage box to www.yahoo.com and restart your computers. It may allow yahoo to work. good luck!
Oct 18, 2008 | Yahoo Mail
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion dv6000z Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
