Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Lexmark 5400 paper jam
One side goes in faster than the other, how can I fix it?
    Genius:
  • 3,587 Answers
Posted on Feb 25, 2008
Paper jamming
Try disconnecting for a while and see if it resets.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
While feeding the printer sheets of paper one side goes through faster than the other and the paper becomes jammed...what can i do to fix this
There is no easy fix unfortunately... once this happens it really is a job for a Tech.. as the entire unit has to be stripped down to replace the bits that cause it...Thats IF one can get parts?
Mar 05, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lexmark 5400 printer, paper not feeding, help
You can try the following. Remove all paper from the printer and turn printer off. Try opening the printer as if you were to remove the ink cartridges and check for any paper jammed in the printer. If there is a paper jammed try to remove it. if there is no paper jammed in the printer then try the following remove all paper from the feeder and flip the printer upside down and shake it a little. Sometimes things will fell inside of the paper feeder and will block the paper path thus causing the printer not to be able to pull the paper.
Jan 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have paper in the lexmark 5410 and it feeds one side faster so that a paper jam occurs. How do I fix this problem? Thanks,
This may due to paper feeder roller of other side was having problem/faulty. Replace/repair the same will solve your problem.
Dec 15, 2009 | Office Equipment & Supplies
Paper Jam Problems
go the control panel and go to the printer then open the printer that you are using!! you need to cancel all printing document and after you done this.......just restart your pc
Jun 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
The paper jams up when the printer pulls it into print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 21, 2009 | Lexmark X4530 InkJet Printer
On the 5400 lexmark if a paper jam occured, how do you fix it,do you have to unscrew the back in order to get the paper that has jamed?
No just pop of the back tray and you should have access to it from there. Make sure though to unplug your Printer and your printer need you to reset it.
plz rate thank you
Sep 07, 2008 | Lexmark Office Equipment & Supplies
My lexmark 5400 keeps saying "clear carriage jam". I cannot see anything jammed but i can't use it till whatever is cleared. please help!
  1. Press Power to turn your All-in-One off.
  2. Unplug the All-in-One.
  3. Check for paper jams.
  4. Plug in the All-in-One.
  5. Press Power to turn the All-in-One back on.
If the error exists .. then printer is defective contact lexmark ..
Mar 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
