Question about Coby MP-C7085 MP3 Player
Write-protected? when i try to copy-paste a file into the player (F drive on the computer) and it says it's "write-protected". i did it before and worked fine. is there a certain limit on how much videos can be on it?
You Probably Had It On Hold.............................I had the same problem anyway slide the hold button so the you don't c the orange side!!!!!!!LOL!!!!!!!:)
Posted on Mar 26, 2008
Though, for some reason, it deletes the songs i have on it...
Posted on Mar 24, 2008
  • 3 Answers
U can`t do that u have to do by windows media player
Posted on Feb 08, 2008
I got a CD-RW and i wanted to transfer the music automatically to my mp3, but when i tuned them into MP3Format it didn't transfer because it was write-protected. Somehow that has affected my mp3 and...
Try transferring directly from the disc and don't use the 'automatic' transfer that a computer sets up for you. the computer has to follow all the rules and regulations, but if it's for personal use, go to the My computer and select the CD drive, open files and copy/paste to where you want them.
Jan 17, 2018 | A D S Creative ZEN Stone MP3 Player
How can i put pictures on my mp3 palyer
Connect your MP3 player to your computer with the USB cable.
Then copy and paste the picture files from your computer to the picture folder in the MP3 player.
Sep 07, 2010 | Audio Players & Recorders
How do remove 'write protection' ? So you can copy and paste files onto it.
USUALLY HAS A VERY TINY SWITCH ON THE SIDE OF THE MEMORY CARD.
May 28, 2009 | PNY 2GB microSD Memory Card
Can't copy file from computer to MP3 player
In any windows program, you should be able to go to My Computer, double click the icon for the extra drive, it may show up as an external usb device, rather than tight clicking and choosing copy, try dragging the itunes folder to the new destination, i.e. your usb device.
Jan 13, 2009 | TruTech SMP-1 GBL MP3 Player
PNY Write Protected
Check and see if you can copy and paste that file from it's location and place it on the desktop. Basically seeing if you can move that file within your PC. If this is a work computer, it might have precautions built-in to write protect it's documents. If you can move the file around in your computer then it's probably a problem with your flash drive. Can you copy anything to the drive?, such as a simple text file, music, etc. I'm also assuming that you checked the properties on the drive itself to make sure it wasn't locked. You could also try another flash drive to eliminate the possiblilty of your stick being defective.
Let me know how you do.
Sep 05, 2008 | Computers & Internet
The "motorola phone tools" version 4 disk that came with my W510 motorola cell phone will not download to my computer.The following pops up about half way into the setup: feature;program...
Make sure the disk is clean and you do no have any virus protection running while installed. Disable you virus protection.
  1. Go into My Computer, right-click on the drive that contains the CD, Select Copy.
  2. Navigate to your Desktop or other location you will remember. Right-click Paste. (This will create a folder of all the files on the CD Drive where ever you paste them)
  3. If the disk copies successfully, open the folder you have just created. Run the Setup.exe application and install. (However, if it fails to copy there is a problem with the CD or the CDROM drive. In most cases a cheap drive replacement is always available.)
This problem usually occurs when the spin rate of the disc and drive are not transferring data sufficiently to install. This can also be interrupted by virus protection that is reading every file being installed. Other possible problems are loose drive cables, software, poorly burnt discs or damaged media.
Hope this helps.
Aug 06, 2008 | Computers & Internet
When i connect joybee in my pc, i can not see my files
umm are your files on the mp3 players hard drive or on an SD card?
if they are on the harddrive, plug the usb cable into computer and mp3player, go to 'My Computer' there should be a new drive found called Joybee '130 (E,F,G,etc:)' double click this drive, withinn the drive should be three folders, FMRadio, MICIN, and MP3, double click mp3, drag and drop (or copy-paste) the mp3 files into the folder and you should be good.
If your files are on an SD card, you will need an SD cardreader, plug the cardreader into the computer, and again drag and drop(or copy-paste) the mp3 files onto the card
May 29, 2008 | BenQ Joybee 130 MP3 Player
How do I fix a drm problem in windows media player 11
DRM, which specifies whether tracks copied from CDs in Windows Media Audio (WMA) format are protected files. A license, which helps protect the copyrights of artists by preventing unauthorized distribution, is required to play protected files.
If you're trying to play your copy-protected files on a new computer, you can migrate your protected music from one computer to another by doing the following:
Windows Media Player 7.1 or later
1.
Try to play the copy-protected file again.
2.
In the message that appears, click the More Information button.
3.
Follow the instructions for migrating your licenses.
1.
Download the Personal License Update Wizard for Windows Media Player (http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0048.mspx)and follow the instructions.
2.
3.
4.
A license can be migrated ten times. After this limit is reached, you will receive an error when you try to migrate the license again (for more information, see the Windows Media Player FAQ). When this occurs, you will need to rip the file from the CD again.
note.gif Note If you still have the CD in your possession, you can rip the tracks from the CD again, but with copy protection turned off.
May 09, 2008 | Computers & Internet
"Synch problem: Synchronise to continue your music subscription"
I would suggest formatting the unit and trying again, but this time do not sync it with media player. Plug it into your USB and got "My Computer", the player will show up as a removable disc usually drive f:, right click on the drive and hit format, quick format shoudl work. Once formated double click the removable disc drive, and then click and drag or copy and paste your music into this drive and see what happens. That player should support WMA files, but just to let you know, if you convert those files to MP3 it will take about half the space and therefot you can store more music at once. L8R Hope this helps and good luck
Sep 16, 2007 | SanDisk Sansa E280 MP3 Player
Coby MP-C7085 MP3 Player Logo
21 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
