Question about Epson Stylus C60 InkJet Printer
Both the Red and Green lights are burning steady
I was given this printer by a fellow teacher who didn't know if it worked or not. After I first intalled the drivers, it powered up and tried to print a test page. At this point I discovered the there was no ink or had dried up. I ordered remanufactured ink cartridges in both black and the tri-color. I installed the cartridges and then both the red and green LED came on burning steady. I have no clue to what this means. I would appreciate your assistance.
  • Delbert K Feb 08, 2008
    I removed the remanufactured cartridges and reinserted the Epson brand cartridges. Now both lights are blinking. What does this mean? Thanks for your prompt response.
    Problem Solver:
  • 22 Answers
K, heres a long 1...=P
>the green light is just your power light, if it is glowing, its on, if its blinking...its receiving a job/replacing cartridge/charging cartridge/or cleaning heads
>the red light being constant on is any of the following...
-ran out of ink, ran out of paper, or has a paper jam.
hope this helps.
PS: re-manufactured cartridges can not always be trusted...some companies accidentally send empties...simple mix up im sure,we're all human after all, but be on look-out.
Posted on Feb 08, 2008
  • Brad Drenc
    Brad Drenc Feb 08, 2008
    ok, flashy problem....lol
    the printer may have an internal error. turn it off, wait approx. 10 sec, then turn back on..if this does not solve the problem, that is when this site is useless, and u must contact EPSON support.
    good luck =D
I have a Mitsubishi WD-73737 and when I turn on the tv the power light flashes very fast for a minute then stays a steady green and the screen is a solid blue. There is no sound as well. I have tried the...
Do you have the input turned on that you use the xbox for? Try different inputs as well. If you are getting the menu to come up, the blue screen is telling you that you don't have a signal being run through that particular input.
Mar 21, 2013 | Televison & Video
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Aug 02, 2010 | Samsung ML-2240 Laser Printer
We replaced the lamp in our toshiba tv but only the red steady light and blinking green light goes for 8 times then steady red/green this is the second lamp I have put in with same results-old one really...
you just have to call the manufacture so they can help you reset your tv the tv has to know that you did put a new bulb in there just like your printer asks you did you replace the ink the tv has a simular question. you probaly missed the re-sync question that pops up when you turn tv on and you use your remote arrows to answer its easy the maker of the tv can give you the rest info then you will not have that problem anymore.
Nov 04, 2009 | Televison & Video
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
No picture; No sound
how many times does it blink red? It should blink so many times then stop then blink again. how manty times does it cycle?
Jan 02, 2008 | Sony KDF-E42A10 42 in. LCD Television
Red light on with green light
This is more than likely a sensor issue. Fellowes Customer Service can advise you on a solution with a little more info than provided. 1-800-945-4545
Oct 16, 2007 | Fellowes PS70-2CD Shredder
Epson Stylus C60 InkJet Printer Logo
173 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
