Question about Canon BJC 2100 InkJet Printer
Not printing i changed the ink and the head some 9 months ago ....i intially thought i was out of ink ... but still Nothing on  the paper. Thank you
  • 168 Answers
Try taking a paper towel, and spray it with Windex (with amonia).
Take the cartridge out, and wipe the bottom of the cartridge with it.
This will wipe away any dried ink on the print head.
Then if you take a dried piece of paper towel, and press down on the bottom of the cartridge by the heads for about 5 seconds, you should see a spot of ink.
If that doesnt help, then repeat the above steps and try it again.
Last resort, try a new cartridge.
Good luck.
Posted on Feb 08, 2008
When i print from my computer to laser printer, it just printed nothing. When i put paper and print direct from the printer, it did the same thing. I can still do it as scanner, but just can not print. No...
Ibuy A EPSON T-60 printer,i month ago,i use refil ,but i need daily head cleen,blue ink print iresult is not good,becuse,daily head clinig must,If daily head clean my printer can damage?
i am bangladshi, what refil drum is good for epson t 60.what is name?
Thak you SIR.
Sep 21, 2011 | Epson TM-T60 Printer
Hi! I installed new ink cartridges almost a month ago and that same day I had no problem printing. 1 week later it was printing extremely faded. Thought it was a fluke, but tried again tonight and it's...
Hello!
We all as a canon printer consumer is needed to use Pro dot ink to refill. Please remove your cartridge and clean up the cartridge head tightly by soft/toilet paper and replace again. If it doesn't work clean it again and again... thanks
Sep 13, 2011 | Canon PIXMA MP160 All-In-One Printer
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Sep 10, 2009 | Brother MFC-290C Printer
Canon iP90 stopped printing in BLACK
hi... it might be that you need some time to let the ink absorb into the pads in the print heads ... this can take between a few hours and a day... Must be frustrating to deep clean three times and just seem that you are wasting ink cartridges, my "solution" would be to give it time or possibly clean the print heads manually.. hope it will solve it out..
thank u!!
Feb 10, 2009 | Canon PIXMA iP90 InkJet Printer
My printer has ink and it wont print it feeds through and sounds like its printing but nothing is there
You can try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 02, 2008 | Epson Stylus Photo 890 InkJet Printer
Kodak 5100 will not print consistently
I am currently having the same problem with a 17" iMac Intel Core Duo.  The printer worked fine for a few months, now it will only print in black and white and sometimes in color that is extremely faded.  I have tried every troubleshooting tip in the book and still no luck.
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
No Print
remove the cartridge and set it on an alcohol-soaked paper towel in the kitchen sink for about 15 minutes. If the towel has not begun to draw ink out, then tap cartridge firmly against your other hand which is holding the towel. if still none, then try heating the alcohol to about 150 degrees and repeat. if still nothing, then ink is either spent or cartridge head is dried up. take it to cartridge world (or similar outlet store) and they can get a cheap replacement.
May 31, 2007 | Canon BJC 3010 InkJet Printer
Nothing prints on the paper for incoming faxes or copying a document.
i suspect you are correct in cleaning the unit.inkjets if not used often enough the ink will clog the print head. usually the easiest solution is to keep cleaning unit it works again. other wise to clean the print head manually requires the unit to be completely dissambled. it takes a long time to fix it this way. or if replacement costs are acceptable you can replace it. i would just give it a dozen or so more cleanings.
Aug 23, 2006 | Samsung SF-335T Plain Paper Inkjet Fax
Canon BJC 2100 InkJet Printer Logo
53 people viewed this question
old marine
old marine
