Question about Toshiba 44NHM84 44" TV
Toshiba 44nhm84 Recently, my picture was getting dimmer to the point where I can barely make out the image. I replaced the lamp (TV is 3 years old), but the condition persists. Any thoughts? David
  • viva3 Mar 27, 2008
    I have the same problem. I tried replacing the bulb but that didn't help make the picture any brighter.
  • Andylid Apr 10, 2008
    I am having the same problem, I just replaced the bulb because I thought that was the probelm, however it hasn't gotten any better.....any thoughts. I am going to call Toshiba tomorrow.
This happened to my 44nhm84.  The problem turned out to be the light tunnel, which is an arrangement of four little mirrors mounted between the lamp and the color wheel inside the light engine.  One of the mirrors had come loose and was blocking the light transmission pathway.  I used a little dab of glue to hold the mirror in position, and the problem was fixed.
I've read about other reports of problems with the light tunnel, but usually they say that only one side of the picture is dim.  I think it depends on which end of the light tunnel gets blocked.  If the end towards the condenser lens is blocked, then the blockage will be imaged on the screen.  If the end towards the lamp bulb is blocked, the problem is well out of the focal plane of the lens, so a general dimming is the result.
Posted on Jul 03, 2008
Hello.. Has anybody found a fix for the dim picture?
Posted on Jun 17, 2008
The picture on my toshiba 44nhm84 does'nt seem bright enough.can you help?
hi,
check the brightness setting on ur tv. if u have already checked it, then check ur tvs lamp. its time to replase the lamp. may be its reflector get damaged. thats why the brightness is low.
ok
Dec 31, 2010 | Toshiba 44NHM84 44" TV
I have a Toshiba model 44NHM84 DLP projection TV that will either attempt to power on but then shuts down or when it has powered on there is good sound but no picture.
You will probably find, cahnging the lamp and resetting the timer will fix this problem.
Contact Toshiba for more information if you need to.
Toshiba.com
Oct 24, 2010 | Toshiba 44NHM84 TV
Tv very dark what can i do brightness tured up full still very dark
First check this points:
1. How old is your TV.
2. How many times you have change your lamp.
3. Any sort of weird sounds on the back of the TV.
If you are having problems whit the brightness of your TV or you are seeing a dimmer picture, you might have to change your lamp or your ballast, if it comes to a point where you do not see any image at all but you still hear a sound, then its definitely the lamp, if you dont see image or hear any sound, you might have problems with your ballast, also when your ballast begins to run out the picture can get dimmer due to it sending less amount of voltage to the lamp, i suggest to check with a tech to confirm it, or get a second opinion. Hope i could be of assistance.
Mar 16, 2010 | Sony KDF-E50A12U 50" LCD HDTV
My Toshiba 44NHM84 does not power up. The
It is possible the ballast has failed
Mar 04, 2010 | Toshiba 44NHM84 TV
My picture is foggy is there coolant that needs to be replaced in a toshiba 44nhm84
This type of TV doesn't use coolant. I would suggest to clean the mirror that reflects the image from the optical engine to the screen before replacing the lamp.
Let me know if you need further assistance.
Jan 01, 2010 | Toshiba 44NHM84 44" TV
Sony KDF E42A10 picture loses quality.
It sounds Lamp is weak and causing darker picture.
How old is this TV and did you replaced Lamp recently?
If lamp has not been replaced in past 2-3 years then its time for new lamp, XL-2400 available in Sony Accessories Store and lamp replacement procedure is written in user manual.
Thanks.
Nov 05, 2009 | Sony KDF-E42A10 42 in. LCD Television
Toshiba 44NHM84 has no picture just red flashing standby light
during transportation your TV was suddenly shock. then causes your TV lose connection on main circuit board. trust me!
May 21, 2009 | Toshiba 44NHM84 44" TV
Shadow down right side of screen on a toshiba 44NHM84 44" DLP television
shadows at the bottom of the screen sound like moisture that was "wicked up" between the screen layers and dryed out leaving a stain. DO NOT get these screens wet, use nothing but a damp soft cloth; just a few drops of water running down the screen can cause a fairly large stain. Some people have suggested that they may be professionally cleaned, but the risk of damage is too great on the user level.
Nov 12, 2006 | Toshiba 44NHM84 44" TV
Toshiba 44NHM84 44" TV Logo
558 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
