Question about Hitachi 50UX57B 50" Rear Projection Television
What is wrong with my tv
Hey can anyone help i just bought this tv from a neighbor and the tv is like having withdrawls it shows the picture twice like a shadow its a hitachi 50" 50UX57B
  • chris21 Feb 08, 2008
    whats a heat sink look like ita 1991 is in in the middle of the tv
  • 579 Answers
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conducting piece of wood to push the heat sink when doing tests.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Posted on Feb 08, 2008
  • Greg Collins Feb 08, 2008
    Heat sink is a slab of aluminum with extruded fins on one side.
Magnavox tv has intermittent pixelation and snow breaking through on picture on all channels. Have had cable service out twice to replace digital DVR box but still a problem. Brand new HDMI cable too.
If your TV is connected to the cable box with only an HDMI cable, the problem should either the cable company equipment or outside interference. A bad HDMI cable with cause intermittent or continuous complete loss of picture. Try plugging the HDMI cable from the cable box into a different TV (if you can borrow one) then you can prove if the problem is with the TV or the cable equipment. Maybe a neighbor has a ham radio that is causing interference? (They will have a tall antenna at there house, so easy to see.)
Dec 22, 2014 | Magnavox Televison & Video
I have a Studio 42" rear projection tv, The picture is incredibly bright, have tried to adjust the brightness but it doesn't help....can anyone help me?
I believe these were made by Samsung. You will need to search for a service manual for more specific information.
May 16, 2014 | Orion STV2763 27" TV
I have a 42 inch vizio VW42L and a few months after I bought it sometimes when I go to turn the set on I get sound but no picture. To the point where the backlight of the tv doesnt even turn on. I usually...
Tell Vizio send out the tech.to replace ur Backlight video inverter board,it dying go to be dead sooner or later.Or take the refurbished tv ur tv will have dead video soon.
Sep 07, 2009 | Vizio VW42LF 42 in. LCD HDTV
My Daewoo TV is showing a yellow tinted screen...
this problem actually come from crt socket ic board (just patch behind the picture tube) need to properly clean and resolder back the joint please consult with your tv repairer and i think it not cost much
Mar 24, 2009 | Daewoo DTQ-19P2FC 19" TV
Sound interference... The Box Super & NT*L
the cable is in the wrong connector you need to put it in the Cable in; not tv in that will sort it out .
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Showing
ok you have convegence problem. i suggest you read "fl231 problems under tips in tricks of my profile. this could be a simple easy inexpensive repair. i believe you can get to it under my profile. if that dont help then let me know i will help you further
Sep 20, 2008 | RCA HD52W59 HDTV Projection Television
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
TV goes off as soon as it is turned on
Hey did anyone help on this? I have the same problem.
Nov 22, 2006 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Hitachi 50UX57B 50" Rear Projection Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
