Question about Panasonic PT-LB60NTU Multimedia Projector
Driver for the Panasonic PT-LB60NTU
I need driver for the Panasonic PT-LB60NTU for a MAC computer
    Genius:
  • 1,226 Answers
I find the driver for almost two hours, sad to say that there is no driver of your projector.
I went to panasonic website, driverguide.com,i google it. in yahoo search. is no luck.
I will keep digging, i notify you if there is.
this is the result when i search in panasonic website.
http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832046&Ne=&Ns=&Nr=12001&No=0&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogId=11017&storeId=15001&Ntt=PT-LB60NTU
Posted on Feb 08, 2008
    Brigadier General:
  • 6,966 Answers
To my knowledge, the Panasonic PT-LB60NTU's wireless connection to a MAC is not supported, sorry.
Kind regards.
2 Suggested Answers
SOURCE: i need a wirless driver for a mac computer
hello
Posted on May 16, 2008
A yellow blob in the middle of the picture and it seems to be growing
1,check it ,clean the Lcd panel with alcohol, maybe the yellow blob will disappear
2,if it is not,it seems that the LCD panel is failing
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | Panasonic PT-LB60NTU LCD Projector
I turn on unit and it turns off like ten secondfs later
check the lamp for any bubble like structure on the filament.if ok
the ballast unit has to be at fault
replace the ballast power supply!
Jan 11, 2013 | Panasonic PT-LB60NTU LCD Projector
Panasonic KX-CL400 Color Printer driver for Apple MAC OS 10.6 - Mac OS X Snow Leopard. Need recent driver. drivers from Panasonic web site are not working. Thanks..
You need to redownload the drivers for your crystal eye web cam. Go to this link: http://panasonic.net/pcc/products/printer/download/cl400download.html#download6
When you get there, It will show all the drivers for your operating system and then download the Printer Driver & Utility for Mac OS X 10.1 - 10.5.6 Hopefully this will help...good luck.
Aug 17, 2011 | Panasonic KX-CL400 Laser Printer
Panasonic lb60ntu will not project and none of the power/standby lights will come on. The fan will come on for a minute and then shut itself off. The bulb was replaced and no changes.
Do any LED lights come on? Almost every projector has error codes which indicate where any problem may lay. If you don't have a manual you can download one here
http://www.projectorcentral.com/pdf/projector_manual_3264.pdf
Did the previous lamp fail catastrophically (ie. did it explode?). It is always worthwhile removing the the new lamp and replacing it with the old one. On occasion lamps can be fitted but not fully seated which causes problems.
Make sure that you clean the air filters (if present) and reset the lamp timer (if possible).
Is the projector still under warranty? Once you rule out the basics you'll need to consider specialist repair. Search for Panasonic support in your local region and see who they recommend. Budget models which are out of waranty are often uneconomic to repair when all is said and done.
Feb 14, 2011 | Panasonic PT-LB60NTU LCD Projector
I have a mad do multimedia external hard drive and is asking me for a cypressat2lprc42 driver can you help
You can find the info about this in
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&drid=80310&shortlink=&r_folder=&r_title=
For windows drivers go here
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&shortlink=SD1027
For Mac Os 9 driver go here
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&shortlink=RD1032
For Mac Os X driver go here
http://app.cypress.com/portal/server.pt?space=CommunityPage&control=SetCommunity&CommunityID=285&PageID=552&shortlink=RD1033
Jan 18, 2009 | Computers & Internet
Mac Driver
http://panasonic.co.jp/pcc/products/en/mfp/download/dp-1820/ps/eng.html
here is where you can get a mac driver. but you need a PS"post script" key installed"little electronic board" before you can use this driver. good luck.
Dec 03, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Panasonic dp-3010 MAC driver download
you can go here to get you mac driver
http://panasonic.co.jp/pcc/products/en/mfp/download/index.html#DP-3010
but you need to have a post script key installed in your machine.
Jul 07, 2008 | Panasonic Workio DP-3010 Printer
I need a wirless driver for a mac computer
Hi again,
Seems that you posted twice. Pls, here is the link to your other post.
Cheers.
Feb 07, 2008 | Panasonic PT-LB60NTU Multimedia Projector
Panasonic kx p2023 with a Mac system os x10.39
When you add the printer in Mac select Epson LQ850 driver or install the Generic Text driver. That is your most basic driver for all operating systems
Nov 08, 2007 | Panasonic KX-P2023 Matrix Printer
825 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
