Question about Creative Labs Muvo V100 MP3 Player
My computer doesn,t have removable disk
I put my creative device in my computer, but it doen't do what it used to (small window appears). i started using rechargable batteries about 1 week ago.
    President:
  • 4,402 Answers
Need more info
Posted on Feb 08, 2008
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
Dec 13, 2010 | Sony VAIO PCGK45 PC Notebook
I cannot unistall driver for Live! cam voice. I
Please go the Disk clean up and clean all necessary things and start a disk defragmentation. Then shutdown and restart the computer and reinstall if it doesn't work i will give you another solution
Jan 19, 2010 | Creative Labs Live! Cam Voice Webcam
I just purchased a Creative Zen Vision M on eBay. It is the 5th one I have purchased - mainly because I really liked mine and purchased one for my daughter, son and stepson. Unfortunately, my son had his...
To the support page for Zen Vision M:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=14331&prodName=ZEN+Vision%3aM&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_14331,VARSET=CategoryID:213
The device can be in totally MSC connection mode, seeing the player as a removable disk. Check the setting on the player:
See the small user guide (1.4 MB) on page 20: http://files2.europe.creative.com/manualdn/Manuals/TSD/9604/0x36469568/Zen%20Vision%20M%20User%20Guide%20English.pdf
When the amount of disk space in the removable disk mode is set to its highest capacity, there will be no memory left for the player using the Creative software program on the computer to put media on the device.
Decrease the amount of hard disk space to minimum, to recover memory for transferring media with the media software.
When the procedure above gives no result, reinstall the firmware. Have a download from the support page mentioned above (Europe).
Outside Europe: access the support page from your country for the required firmware.
When more help is needed, just post a comment.
Nov 23, 2009 | Creative Labs ZEN Vision:M Digital Media...
Im having a problem when connecting my creative zen to my computer my computer will not read it
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine:
ending up with "Cannot Install this Hardware".
Solution:
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Note: when using MSC mode always safely remove hardware, the players' removable disk. The icon in the right corner of the task bar.
Once the device can be reached in MSC mode it should be ready to install new firmware on the player:
1. Backup data on the player to the computer when not on the PC already.
2. Reinstall / update firmware from computer to the player: after this the device will have all the maps for writing data and it can be approached in MTP mode again, using application software like Windows Media Player 11.
Online support page for guides, software and firmware for the Zen Mozaic, see:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_17897,VARSET=CategoryID:213
Need more help, just post a comment.
Nov 13, 2009 | Battery Technology Creative Technology ZEN...
1st. mosaic cant be read on my windows mediaplayer as a device.
well what you should do is look for a program creative centrale use this link download the one that says download the starter pack then run through every thing and there you can put music. pic's, and videos on it or if you don't want to do that just go to start, my computer, (plug in your mosaic) and look for the device double click then double click on storage media or what ever and you'll see the music, pic's, and videos folder to put videos on just use the program to put them on.
to get free music in mp3 format get the program free youtube to mp3 converter you can take the url from a youtube vid and paste it on were it says paste and then click download.
HOPE THIS HELPS
Jun 04, 2009 | Creative Labs Zen Touch MP3 Player
Creative stone plus
Initially, it would be possible that the Zen Stone plus is infected with a virus and your PC's antivirus is preventing access to it. Have you tried a reformat of the Zen Stone plus and or a virus scan?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 07, 2008 | Creative Labs Zen Stone Plus MP3 Player
Computer problem, help.
This generally indicates a hard drive crash/failure, in which the hard drive will need to be replaced. Rare, but occasionally you will get this error from an operating system glitch. Before you run out and buy a new hard drive, try reloading the operating system. If you have any problems during or after the install, then the hard drive is shot.
Jul 01, 2008 | Sony VAIO FRV25 Notebook
Creative Zen Touch firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
Mar 15, 2008 | Creative Labs Zen Touch MP3 Player
PC-CAM 880 - remember Webcam mode
Uninstall all reference drivers to camera, reboot then install drivers again AFTER you hook the camera up to your computer.
Drivers can be found by clicking HERE.
Sep 12, 2005 | Creative Labs PC-Cam 880 Digital Camera
Creative Labs Muvo V100 MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
