Question about Panasonic PT-LB60NTU Multimedia Projector
I need a wirless driver for a mac computer
I need a driver for Panasonic PT-LB60NTU Multimedia Projector fo use in a mac computer
Hello
Posted on May 16, 2008
    Brigadier General:
  • 6,966 Answers
Hi again,
Seems that you posted twice. Pls, here is the link to your other post.
Cheers.
Posted on Feb 08, 2008
A yellow blob in the middle of the picture and it seems to be growing
1,check it ,clean the Lcd panel with alcohol, maybe the yellow blob will disappear
2,if it is not,it seems that the LCD panel is failing
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 29, 2014 | Panasonic PT-LB60NTU LCD Projector
I turn on unit and it turns off like ten secondfs later
check the lamp for any bubble like structure on the filament.if ok
the ballast unit has to be at fault
replace the ballast power supply!
Jan 11, 2013 | Panasonic PT-LB60NTU LCD Projector
My Panasonic PT LC76U has horizontal pixelated lines. See image at this link http://abigproduction.us/_images/panasonic.jpg
you need to check:
the Vga cables if the image shown is that from a computer
firstly check if the Panasonic logo comes ok in the beginning
if ok then try connecting a laptop directly thru a short patch cable to the computer port of the projector[i am assuming that the projector has been installed to the ceiling]
if this works ok , then the projector is fine!
you need to figure out the problem with the vga cabling and switchers if any of them are used!
Dec 30, 2012 | Panasonic PT-AE900U Multimedia Projector
Panasonic lb60ntu will not project and none of the power/standby lights will come on. The fan will come on for a minute and then shut itself off. The bulb was replaced and no changes.
Do any LED lights come on? Almost every projector has error codes which indicate where any problem may lay. If you don't have a manual you can download one here
http://www.projectorcentral.com/pdf/projector_manual_3264.pdf
Did the previous lamp fail catastrophically (ie. did it explode?). It is always worthwhile removing the the new lamp and replacing it with the old one. On occasion lamps can be fitted but not fully seated which causes problems.
Make sure that you clean the air filters (if present) and reset the lamp timer (if possible).
Is the projector still under warranty? Once you rule out the basics you'll need to consider specialist repair. Search for Panasonic support in your local region and see who they recommend. Budget models which are out of waranty are often uneconomic to repair when all is said and done.
Feb 14, 2011 | Panasonic PT-LB60NTU LCD Projector
Panasonic PT LB50NTU - LCD projector need to connect to my IMAC - what cord do I need?
The Panasonic projector PT-LB50NTU or E have two type of data inputs.
One is RGB or VGA cable and second is VIDEO cable. If your IMAC have video or vga output than you can connect.
Two type of cables witch are using with projector good_help_0.jpggood_help_1.jpg
Jan 14, 2011 | Panasonic PT-LB50U Multimedia Projector
Network adapter not found when running wireless program
Sounds like the Apple Dealer is onto the right idea.Unfortunately wireless control for projectors is still in it's infantcy and subject to compatability issues. A complicated alternative is to "Try" a wirless bridge adaptor in between the laptop and the projector. using the lan port on the projector, you would set up a mini lan between the projector and the bridge, and you would get a wireless connection between the mac and the bridge.
Probably too complicated, the extra cable may just be the go for now until panasonic release the firmware upgrade for you.
Good Luck in the Courtroom!
Jan 17, 2010 | Panasonic PT-LB80NTU Projector
Mouse arrow projects as a square and I need an arrow
this is a setting on the projects setting menu, it may also be a software setting for the projector
rod
gooto menu look threw options
Feb 03, 2009 | Panasonic PT-LB20U Multimedia Projector
Mouse displays with a square instead of an arrow
lb 20u does not support mac os,yet try the auto setup on the remote , if u are getting the image properly
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Driver for the Panasonic PT-LB60NTU
To my knowledge, the Panasonic PT-LB60NTU's wireless connection to a MAC is not supported, sorry.
Kind regards.
Feb 07, 2008 | Panasonic PT-LB60NTU Multimedia Projector
140 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
