Question about Nikon F5 35mm SLR Camera
Camera Seems to be Locked Up
I was able to shoot one picture with a perfectly good Nikon F5 35mm SLR Camera. I was able to set it to shutter priority and adjust the shutter speed just fine, focus it, and take the shot. The problem is, the next time I pressed the shutter release button, nothing happened. The camera will not focus, adjust mode or shutter speed, or take a picture. It can be turned on and I can view the mode screen, but nothing can be changed or adjusted and it will not take pictures. Help?
  • Kprosser Feb 08, 2008
    The top display does have the word locked above a grid, but the power and battery are fine. There is no ERR word.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Any information on the top display? ERR?, Have you checked power? Battery?
  • 101 Answers
Try reseting the Cam !
Posted on Mar 10, 2008
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
What is the relation of lense maximum apertures and camera settings?
You have not stated which model camera body you have so I can only give you general Nikon information. There is a range over which the automatic settings will work for each camera. In addition, Nikon bodies have multiple sensitivity ranges. On the D90 for example, go into the "Shooting Menu" and open the "ISO sensitivity settings." You will see "maximum sensitivity" and "minimum shutter speed" menus along with the "ISO sensitivity auto control" options. Turn off the auto control option and manually set the maximum (ISO) sensitivity and minimum shutter speed. Also, the Shooting Menu also has "High ISO NR" settings that can be used to accommodate most lighting situations. You need to look in your camera's manual for all the details. The Nikon website has manuals available for all the Nikon products.
Sep 19, 2012 | Nikon D3, D40, D40X, D50, D60, D70, D80,...
Shutter speed actomatic change
If you move from mode to mode, the camera will remember the settings from the last time you were in that mode and reset to them. This is handy if you are in shutter priority shooting sports at a high shutter speed, and then want to take a picture of something that's not moving fast, like the crowd. You just pop it into aperature priority with a remembered settings of a higher f stop.
I use this to shoot the scoreboard, which has a fairly slow refresh rate and usually comes up blank if I shoot it at a shutter speed higher than about 1/100.
Sep 02, 2009 | Nikon D300 Body Only Digital Camera
Nikon D80 red and green streaking
check on the shutter speed and also the Aperture priority..
Jul 27, 2009 | Nikon SLR D80 Digital SLR Camera Digital...
Nikon NEWBIE
put simply the ISO number is how sensitive the film is to light, the higher the number the more sensitive the film. The ISO on the camera sets the exposure system to give the proper exposure for that film (the f/n80 usually sets the ISO automaticly). Also the higher the ISO the more grainy the picture, I would recommend using ISO 200 film for the pictures you describe. I would set the camera to the P setting it is a good all-around setting.
Nov 18, 2008 | Nikon F80 35mm SLR Camera
I have two different lens one is stronger than the other.Sometimes I take the perfect picture then other times not so good.How do I know which lens to use for close up or i want a distant shot at a cl
Do you mean that, you press the shutter release once and the shutter stays open until you press the shutter release a second time. If so, check your shutter speed setting. If it is set to "T" (Timed Exposure) the camera is working correctly. Change your shutter speed to an appropriate setting, such as 1/125. If that does not solve the problem, you might need to take it in for repair.
Nov 10, 2008 | Nikon F65 35mm SLR Camera
Photos have streaks
Sounds like you are shooting at shutter speeds of 1/30th of a second or slower, and/or your flash unit is set to "slow sync" or a similar mode. Try shooting in shutter priority or manual, and using a speed of at least 1/60th but not more than F4's sync speed of 1/250th. If you are shooting a moving subject, you may find that this "problem" actually creates some very interesting effects.
Sep 24, 2008 | Nikon F4s 35mm SLR Camera
Shutter speed
shutter speed has nothing to do with battery power. If you have a SLR camera you use the shutter speed option when you want to have control of the shutter speed, slow shutter speed means if your taking a picture of a waterfall and you want to see the actual droplets you set a slow shutter speed, if you want it to look more smooth/flowing you set a faster shutter speed, if you do not have a SLR camera you probably dont have much say so in shutter speed...
May 28, 2008 | Nikon FE 35mm SLR Camera
N70 FE E error in LCD and view finder - lens locked properly
Yes, the error is due to your lens not being set to highest F number. Solution : set lens to the highest number ( f 16 or f 22 ) and lock it in ( on the lens ). Your camera will work find now.
Oct 07, 2007 | Nikon N70 35mm SLR Camera
Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Oct 21, 2006 | Nikon F100 35mm SLR Camera
Nikon F5 35mm SLR Camera Logo
175 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
