Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Kf60xbr800 internal lamp component, what is the replacement costs for such parts
Tv turns off and on by its self stanby light flashes continuously inbetween cycles, turn tv off by opperator stanby light flashes 5 times pauses and repeats.the kf-60xbr800 was bought in 2003 engine has been replaced less than a year.
  • 1 more comment
  • Rod510 Feb 08, 2008
    Replaced the lamp (xl2000u) and the tv is working just fine, thanks for all the help.
  • jram Feb 13, 2008
    POWER LIGHT FLASHES CONTINUOSLY AND THEN THEN IT GOES TO A STEADY RED LIGHT ALONG WITH THE LAMP LIGHT IT ALSO GOES IN A STEADY RED LIGHT.
  • jcolosi Feb 28, 2008
    I have the same issue. The symptom has these steps:
    1. TV is on
    2. TV will go into a standby mode, picture goes black
    3. The red LED on the front will flash for about 30 seconds
    4. The picture returns
    At first this process repeated itself once every few hours. Now it is on for 30 seconds, off for 30 seconds.
    I believe I need to replace the bulb, but I'm not sure how.
  • Sony Master
  • 5,138 Answers
Go look at your set up timer in menu see what it says some sets will tell you to replace lamp, while other types of DLPs just start turning off and on ,their may also be something wrong with area around lamp too.Read your service manneul or get one on www.free service manneuls.com . ThankYou for using FixYa.Have a Nice Day.
Posted on Feb 08, 2008
We went to bed and switched the tv from standby to on and after 1 min the tv turned its self off back into stanby, now if you turn it on it flicks onto a black screen with dtv in the corner and switches...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help you in solving the problem....
Jun 18, 2011 | Televison & Video
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Stanby light flashes green and looses the signal tv turns to stanby then comes back on this happens about every 10 minutes
For the KDSR60XBR1, 5 blinks, pause, 5 blinks, etc. means "Lamp driver error" and the probable cause listed is "Lamp driver is faulty".
You may purchase the lamp driver (power supply block), part number 146893612, for $161.86 at http://servicesales.sel.sony.com/web/productSearch.do. Use the Part or Accessory Number to look it up."
Jan 25, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Why does my tv turn on for a little bit but cant see the screen and a red light flashes
Tv red LED lights indication front of the bazel screen flashing are most common problems.When was the last time the projection lamp was replaced in this tv?The lamp in the tv now,is it in the the tv about 1 1/2 or 2 years and tv on watches about 4 or 5 hours a day in used?The projection lamp life are over.Require a new projection lamp.
Aug 03, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
My sony kf-60xbr800 keeps tirning off and on
If lamp has not been replaced in last 2-3 years then replace it, this tv turns off and on because of dying lamp.
Let me know if you see standby/power light flashing on tv front, this is an error code that shows some other problem instead of lamp.
Aug 01, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
My KF60XBR800 will not always power up when we
Replaced the projection lamp again.Sony projection lamp more expensive,but last longer too.Genaric projection lamp brand last about 1 1/2 max.U hear clickinng sound too,when LED light flashes?Mean the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Jul 07, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a sony kf60xbr800 60 when i press power
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is XL2000 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2000+?Click=48173
Nov 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony 60 in projection tv makes weird noise
Did you hear that wierd noise 3 times after you turn the TV on? if so the ballast is working try replacing the lamp XL-2000u
May 27, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony kf-60XBR800 lamp
Count the flashes of the standby light and the gap between the flashes as the tv is giving you the exact error code for the fault this way. Then check in the handbook and sony forums for the solution. Personally I have found ALL sony products to be like a spoilt rich kid, replace the parts with genuine sony, if you dont it mis-behaves itself in ways never seen before. Good luck.
Sep 18, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
