Question about HP Photosmart C5180 All-In-One InkJet Printer
Paper jam Hi. I went to put more paper into my printer, and i found a piece jammed into the back of the printer and it won't catch on the spinner in the back correctly, and I guess i need help on how to get it out? Does anyone know how to take apart the printer so i can get to the paper?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
I suggest you to contact your nearest service center in order to fix this issue:
http://hp.via.infonow.net/locator/us_partner/
Regards,
Sagar.
Posted on Jul 27, 2008
I have a paper jam many pieces went through the printer and won't budge. I don't see a way to get to where the paper is stuck
Unplug the printer from the power source to turn it off. Open the printer cover to access the cartridge area. If you see the paper jam, slowly and carefully pull the paper out of the printer. Avoid tearing the paper or avoid leaving torn pieces in the printer. This will cause future paper jams in the printer.
When all is clear, re-plug the printer into the power source. Load some paper and try to print again.
Jul 24, 2011 | Lexmark X2600 InkJet Printer
Paper jam I got the big piece of paper out but cannot find the small piece What can I do
Hi
The paper jammed can be found in the paper tray, inspect for a paper jammed and feeder roller.
It can be found in the cartridge compartment inside the printer.
If you use the top feeder when copying, it might be there in the top loader paper. open and inspect there
It can be found in the toner cartridge itself.
Lastly, it can be found into the back door of the printer. Check for the door both sideways or back door of the printer.
Mar 06, 2011 | Brother MFC 240C All-In-One InkJet Printer
Error code E-04
I would check that there is nothing inside the paper feed system. The smallest piece of paper might cause a jam. Take the inks out and give the printer a good shake then put inks in and try again.
IHave you had a jam recently and pulled the paper out to clear it?
Jan 10, 2010 | Epson Stylus CX6000 All-In-One InkJet...
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
Paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My paper has been jamming when fed from the back. I found a foam piece that has come from somewhere in my machine. the piece is about eight inches long and seems that it might have had an effect on the...
try this
alternative :
Jun 08, 2009 | Canon Pixma MP800 All-In-One InkJet...
Paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Jamming problem
try this
alternative :
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
