Question about SanDisk Sansa e250 MP3 Player
Formatting OK, I read the User Manual for the Sansa e250. It mention Format as an option, and which seemed to be around the settings menu, but I never was able to find this option. I need to format my device back to factory settings; no music, videos, pics, nothing. I have tried a couple of tricks but nothing seems to get the job done right. Ayudame! Porfavor. Please, any suggestions would help.
  • 1 more comment
  • Kevin Brookes
    Kevin Brookes Feb 08, 2008
    Thanks for the advice, but already tried a and b. For some reason, the Format is gone, which kinda sucks. I have done the recovery tool, and it didn't seem to do much, but I will try again. Thanks for the suggestions.
  • Kevin Brookes
    I appreciate everying thing that you are doing and can do. And yes, by all means get assistance. Thanks so much. Cheerio!
  • Kevin Brookes
    That is perfect thank you.
E250 manual
Posted on Sep 18, 2011
    Brigadier General:
  • 6,966 Answers
If for some reason the Format option is gone, then perhaps some of the firmware or settings have been drastically changed or worst, corrupted.
A couple of things you can try:
a. do a soft reset - press on the Power/Menu for 15 seconds;
b. do a full settings reset - Main Menu/Settings/Reset All;
c. do a Format - Main Menu/Settings/Format but all in the internal memory will be erased;
If the above will not work, you can also try:
1. download and run in your PC Sansa Connect Recovery Tool
2. read the How to use the Sansa Connect Recovery Tool and follow the instructions carefully;
3. doing #1 will erase the corrupted files, unfortunately so with everything else. It will then restore the device software to an uncorrupted state.
Hope this be of help/ Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 07, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Feb 08, 2008
    Hi again,
    I understand and really hope we can figure something out. With your permission, I would be asking a tech buddy to assist, hopefully he would be in a better position to provide assistance.
    Cheers.
  • Louie  Role
    Just bringing you uptodate. Left a message for my tech buddy (computerrep ) to post here. I have no doubt that he will be able to resolve your concern since he is with the firm that manufactured your unit.
  • Louie  Role
    Louie Role Feb 09, 2008
    With the indulgence of computerrep, I am taking the liberty of providing the link to his solution to a slightly similar problem.
    Should this be corrective, it would be appropriate that he be credited for solving the problem.
    Thanks for using Fixya.
How do I reset my Sansa e250?
For resetting Sansa e250 to factory settings:
Start from Main Menu.
Next select:
Settings (image of an equalizer)
Reset All
Yes
Having problems reading the language first choose yours, select:
Language is the 5th option after Settings
Change the language to the language you prefer
Jun 20, 2010 | SanDisk Sansa e250 MP3 Player
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Sansa E 250 bad track
On your e250, go to the "Settings" menu, select "USB Mode", and set it to "MSC". Then connect your e250 to your computer. It show up under My Computer as a "removable disk". Right click on it and select "Format". Click on the "Start" button, making sure that Quick Format is NOT checked. Wait for the formatting to complete, unplug your e250, wait for it to reboot (or force it to reboot if necessary), plug it back in, and copy your songs back onto it.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
No manual,don't know how to use,or set it
Go to the website below and download your pdf format user guide. The user manual will say e200, but it also applies to e250. Good Luck, I hope this helped. Please rate me, Thank You
http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
Dec 12, 2009 | SanDisk Sansa e250 MP3 Player
How do i reset my sansa e260 without using a program and if i have to use one where can i get it online for free
1. Press the "Power/Menu" button and select "Settings" and then select "USB".
2. On this screen, select "MSC".
To format your Sansa, please follow these steps:
1. Plug your Sansa into your computer then open "My Computer", right-click the drive associated with the player and choose "Format."
2. Set "File System" to "FAT" if your Sansa's capacity is less than 2GB. Otherwise, select FAT32.
3. Click on "Start" to proceed in formatting your Sansa.
I hope that helps..
Computerrep
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Formatting a Sansa e250
Plug it in, open "My Computer" right click your device and click "Format" a window will pop up with the settings on how you want to format it, make sure it's set to FAT, then click "Format."
Hope this helps!
Oct 13, 2008 | SanDisk Sansa e250 MP3 Player
How can i delete music file from my sansa e250
try formatting the player by selecting format from the properties menu when you right click it in my computer.
Aug 04, 2008 | SanDisk Sansa e250 MP3 Player
Formatedmy sansa e250 ntfs
To format it..on your device..go under..menu, setting and there should be a format option option there.. or you can change the device mode to MSC instead of MTP and right click on the drive which is listed under my computer and click on format..
let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Jul 30, 2008 | SanDisk Sansa e250 MP3 Player
Formatting my sansa e250..it says reading bootloader and writing bootloader
You Installed The Firmware wrong. (Do This)
1.Connect Your Player to The PC then Format it by right clicking the players hard drive. (F:) , (G:) , (I:) ,Ect.
2.After Formatting the Player go to this site : www.Google.com
Like This:
3.Go to www.google.com Then Search For "Sansa e250 Latest Firmware. OR Try This http://www.anythingbutipod.com/forum/forumdisplay.php?f=51
4. Go To the Page Where The Firmware Is at and Download it
then put it on the player disconnect and turn on normally should say new firmware or sumthin while loading.
Jun 15, 2008 | SanDisk Sansa e250 MP3 Player
Formatting the sansa e250
Yes, formatting will retain the interface and everything else necessary to run the device. It only removes what you have put on the unit. Also, format anytime you begin to have strange problems with the device that can't be explained...like songs that don't appear after you've transferred them.
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
98 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
