Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Gaming Problems When we play my XBOX 360 their is a lag between the controller and the TV. Is this a TV settings fix?
  • 105 Answers
No, it has to do with the amount of image processing capacity available in both the set & the game box.
Posted on Feb 07, 2008
Optimal settings for xbox360 for the LG 42LA660V
I doubt its input lag as this is the first I've heard of it your probably facing a rendering problem so you've either got too much going on your 360 or it is getting too hot which is causing your machine to run slow and lag
Jan 16, 2014 | Computers & Internet
When i play my xbox 360 im getting a lag...my friend said i should have a setting to prevent this but im not sure which one it is or how to do it..
Everyone experiences lag from time to time. Lag is often the Xbox (Microsoft) servers themselves, however if you are always the lag source, then there are several potential issues and/or solutions:
1) Open/Closed NAT (Network Address Translation): Your NAT should be set to open or not restricted. This is not a console setting. You must log into your router to change this setting. Typically this will fix your issue (especially if game chat or joining is impacted).
Additional changes: Note: If you do not know how to make changes within your router, then get help from someone who does (parent, or write back with your router brand and model number and ask for assistance).
2) Within your Router ENABLE the UPNP setting.
3) Another option: Within your router, assign your console a static IP address. Then set up port forwarding for the following ports: 88 UDP and 3074 UDP & TCP. This way you can keep NAT closed, but allow unrestricted internet traffic to xBox.
4) If using wireless network adapter, unplug it and run a CAT5 cable from the Xbox directly to the router. If your lag issue goes away, then there could be interference with the wireless traffic. If interference, then log into router and change the broadcast channel.
5) High speed internet and traffic: You really need high speed internet (cable or DSL), close proximity to the router and bandwidth to fully enjoy online gaming. If there is a housefull of net users (Youtube, movies, music, gaming, etc..) then you can expect lag issues.
Upgrade to a higher speed package. 3 or 8 Mbps download is fine if you are by yourself, but with lots of activity, then you need 16 to 30 speed (which is really volumetric capacity and not speed). Check your download/upload speed at www.speedtest.net
6) Make sure your Modem (not router) is DOCSIS 3 and not the older DOCSIS 2 versions. Ask your ISP to check your connection for any potential problems. They can typically read this from their end.
7) Check all cable connections coming into the house, all the way to the Modem. If DSL, then check phone lines and filters.
8) Finally, and I am sure this never happens, if surfing off of a neighbors system, then stop mooching and buy your own! ;-)
Hope this helps!
Apr 22, 2012 | Video Game Consoles & Games
Xbox 360 slim offline lag
Hi dinobots,
Do you use Wi-Fi or an ethernet cable? If you are experiencing severe lag, it could be a problem with your actual internet connection and not necessarily your XBox 360.
I would purchase an ethernet cable (they run about $10 over here in the states) and try that out before anything else
Mar 19, 2012 | Microsoft Xbox 360 Super Elite (250 GB)...
Xbox 360 games lag just on this t.v. Does not play games right.
Depending on your model, this is caused by visual post-processing which may introduce lag. Many LCD diplays have a "game mode" setting make sure this is on when playing your Xbox 360 through this LCD TV. Also, depending on your model of TV, there are motion enhancers (usually proprietary e.g. LG calls its TruMotion) which can also introduce lag; these should be turned off while playing. Another step that should be followed, is to turning off any set video setting in the Xbox's configuration (i.e. turning off any set video output such as 480p, 720p, 1080i, etc.) and setting it to "Optimal Resolution". This should allow for native video output instead of possibly upscaling which would in turn induce lag.
This should correct you lag issue for most common LCD TV's. Hope this was helpful. Thanks for visiting FixYa.com
Feb 01, 2011 | Televison & Video
Just got an xbox 360 slim 250GB but when I went to play halo 3, the game was lagging along with the xbox menu itself. I even connected a plug-in controller and I had the same result showing that it was not...
If you just bought it brand new, then return it for an exchange. Its not wise to keep an electronics appliance or game console that is having issues straight out of the box. Using your A\V (RCA) cables instead of an HDMI cable shouldn't be causing any lag, at least nothing that is significant enough to notice.
Aug 17, 2010 | Microsoft Xbox 360 Console
Is xbox 360 controller compatible with laptops woth vista? Also can I play FIFA with it?
The Xbox 360 controllers are compatible with Windows Vista, you need to connect it either using the cable or you would need to purchase a "Xbox 360 Wireless Gaming Receiver for Windows"
http://www.amazon.com/Xbox-Wireless-Gaming-Receiver-Windows-Pc/dp/B000HZFCT2
Once you have connected the controller it should work with FIFA
Apr 14, 2010 | Video Game Consoles & Games
X-Box Controller lag on new T.V.
This may be because of HDMI, but I have seen this happen on other TVs that use coax cables. It may be your controller is getting old. If you can afford it, try replacing the controller or get the HDMI connector for the xbox 360.
Mar 02, 2010 | Video Game Consoles & Games
Xbox 360 lag
Works great with a Linksys gaming router.. had the same problem with an old linksys
yes they now make special routers for gaming..unbelieveable huh..you can get one here for under a hundred bucks and it will work great!
Good luck! Happy Gaming!
Jan 19, 2009 | Linksys Wireless-N WRT150N Router
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
