Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark 1300 printer
Printer begins to print then freezes even on test page. have tryed all solutions. chaning hunbs.(or router), cables, paper, cartidges;etc. also changed power source from surge procter to wall. error msg. reads printer not communicating. have changed ports. settings and everything else. i'm usin windows 2000.
  • Lexmark Master
  • 12,061 Answers
Ok it seems to me that your Driver may be corrupted... try a complete un-install of ya printer... go to the Lexmark web site and download the latest driver for win2K, and install it... This may get ya good to go :)
As an aside can you try the printer on another machine? if ya can install the drivers on another machine, and see if thats OK, it is possible the Printer has a "Hard" fault? just a thought.
Posted on Feb 07, 2008
No print with new cartridge on z1300
Try to remove and re-insert the cartridges into the printer carrier and make sure they are firmly inserted into the slot. Try to print again.
Print quality issues can be due to dirty or clogged cartridge nozzles. Try to open the Lexmark Solution Center on your computer to clean the cartridges.
On your computer, go to Start menu > Programs > Lexmark 1300 Series folder > Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print a document again to verify that the problem is fixed.
Oct 28, 2011 | Lexmark Z1300 InkJet Photo Printer
How can I make a printing test without connect my printer to the pc?
How to Perform the Hardware Test on a Lexmark Z840 and Z845 Color Jetprinter Document ID:HO3002 Properties Lexmark Z845How to perform the hardware test; Hardware test; Lexmark Z840 Color Jetprinter; Microsoft Windows 98; Microsoft Windows Me; Microsoft Windows 2000; Microsoft Windows Server 2003; Microsoft Windows XP Professional x64 Edition; Microsoft Windows XP
Solution Performing the Hardware Test
    1. Turn off the printer.
    2. Press and hold the Paper Feed button.
    3. While continuing to hold down the Paper Feed button, press the Power button ONCE.
    4. When the Power button begins to flash rapidly, release the Paper Feed button. A test page will print.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Lexmark Z845 InkJet Printer
I installed new cartridges in my X2550 Lexmark I want to print a test page. It scanned the test page but will not print it. What do I do?
it depends on the error message why the test page won't print. If it just won't print at all, try to reseat the paper into the printer and turn off/on the printer then try to print the test page.
If it doesnt, then turn off the printer, remove cables. And then press and hold the power button on the printer for 5 seconds . Reinsert cables and turn on the printer and print the test page anew....
Jun 04, 2010 | Lexmark X2550 All-In-One Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Hp laserjet 1300 prints extra blank page
Before you get a better answer to me , I hope you would have told us if you are the first person that used it so that we can know if this problem started from the initial point or at the middle time of using the printer
1) Did you add additional memory to the Printer?, if Yes remove and try back.
2) Try you use this printer in another PC
3) Look for HP1300 printer software.
4) It may be a mechanism/paper carriage error which can not be corrected by software unless you change mechanism/paper carriage.
Apr 29, 2008 | Office Equipment & Supplies
did you try the hp laserjetIII driver
Apr 22, 2008 | HP LaserJet 1300 Printer
PAPERJAM
hey gramma try to do one thing before even going for test page , open the panel and cover where u will be able to see the catridge ccarriers, try to blow air, or after opening the cover titlt the print and shake it gently sometimes due to some dust particle the paper jam happens
Feb 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
