Panasonic pt53tw i have cahnged the convergence chips and now when i turn on the tv it starts to turn on but then the power light flashes off and on before turning off
  • ladywinn
    ladywinn May 11, 2010
    Which ics did you replace with same ones or different ones? Also make sure you have everything connected back.I use the STK392-180s they are better ics.let me know if i can help you in anyway.ThankYou for using FixYa. Have a Nice Day.
    Novelist:
    Scholar:
  • 96 Answers
It sound to me that you haven't reconected all cable's, or cause a short somewhere.
Double check all connection, make shure there the same IC's, and all cables or connected at the same place, keep in mind cheap china ic's don't garranty if the set will have solve your problem, alway's try to get japan sanyo part's I have had problem in the past were I replace the ic's and kept trying after 5 times I've ordered the origenal from pioneer and finaly the set turn on, f$%# all that time spent for a stupidity, this happen to me about 7 different customer's for convergence and mostly on panasonic and sony. what can I say.
Regards
What about Bob
Posted on Feb 08, 2008
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Led light flashes thre times
I would initially suspect IC7001 and/or IC7002 on the D board. Those are your convergence output IC's. Those tend to fail after 5-10 years of typical use. Part# STK392-150 is available as a direct drop-in replacement part and repeat failures are almost unheard of. Also, check the low-ohm feedback resistors around these chips. R7011, 7012, 7013, 7014, 7015 and R7016 should all be 2.2 ohms @ 2 watts. If you have a shop do this, the typical price including travel and house call is $300-400. Parts alone are about $50, give or take.
Aug 18, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Replaced convergence chips, have new problem
Did you check the 2.2 ohm 2watt resistors? As often one or two will blow when the old ICs fail. The 3 blink error is indicating a problem with the convergence circuit still.
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to ptscorp.com
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
No power,red power lights keeps flashing.
I had the same problem with the 47" version. I called the Sears technician who tried for more than an hour to fix the problem, even calling Panasonic. Final solution: a board repair for $550. Now I have a plasma and a big desk.
Dec 02, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
