Question about Hitachi 46BX01B 46" Rear Projection Television
Blur tv screen
My tv is yary blury and the colors are off I can not seem to line the colors up by utilizing the little blue dials inside of it
  • christina_gr Sep 19, 2008
    My tv is always blurry We tried to change the dial colors now there is a line on the top of the screen and everything is highlighted
  • Richiebo Nov 22, 2008
    TV colors are off. Foar example: Any typ of writting on the screen is similare to double vision but in blue
    Novelist:
    Scholar:
  • 96 Answers
It sound like you have a convergence problem, not shure,
need more info is your set a rear crt projector style if so then, check for the fuses to see if the sypply to the convergence board +/- 40 volt about is there, check the two convergence ic's they should have the part # stk392 xxx mean's there the one causing the problem ,,,,,, turning any type of dial think you may resolve your problem think again, this will only cause more at the end, you'l see.
Regards
What about Bob
Posted on Feb 08, 2008
I need to know how to adjust for the for clairty of the wording ( to blury to read it)
On the front side of your tv under the screen you have a box with little dials on it. This is your focus and brightness control. There should be six dials. 2 for each tube. Turn the one that says focus for each color slowly one direction or the other until the picture looks clearer.
May 18, 2012 | Hitachi Televison & Video
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
I just bought a Dynex LCD TV. It seems to work
Suggestion: This TV is new and part/labor are covered by the Manufacture Warranty. Contact Bestbuy for service options. It sounds like you have a panel problem. I hope this was helpful, best wishes.
Jul 13, 2010 | Televison & Video
Red and blue color on TV is aligned but blurred, green is ok
U have a CRT Tube coolant problems.Tries Websites MCMElectronics.com,Tv reapair World.com to buy CRT tube coolant to recharge ur CRT.
Feb 26, 2010 | Sony KP-46WT500 46" Rear Projection...
There is blue yellow color blur on the screen with cable or dvd
This problem is of "CONVERGENCE". You have to replace the convergence IC's which is better to buy a new one TV, Just contact any expert and replace the convergence IC's and your TV work fine again you need not to buy a new TV.
Thanks for using fixya.
Jul 24, 2009 | Toshiba 42H81 42" Rear Projection...
Wont work the gameboy color screen shows a blurred nintendo logo
this happened to me as well, from personal experience it seems that your game got to hot and fried the circuitry a bit, i had to get a new game, found out if a little moister gets in there and heats up on a hot day, the power supply on the game system fries the circiutry, if you got it used see if they will return it for a better one, if you recently got it, i hope so...best of luck...shia
May 02, 2009 | Nintendo Pokemon Blue
Screen fades to blue.
The Blue SCREEN setting is too high. These adjustments are located inside the TV behind the front panel. There are two screws behind covers and then a wooden panel to remove to access the adjustments. The leftmost set are for BLUE, the middle are GREEN, and the right are RED. The top row are FOCUS and the bottom are SCREEN. Focus will focus/unfocus the tube and Screen will adjust the power of that tube (there are 3 tubes, one for each color). If Screen is adjusted too high, horizontal lines will appear (my TV had red lines, but I played around with the knobs and saw that it could happen on any of the colors). Additionally, if SCREEN is set even higher than that, the tube could go so high that it turns the whole screen that color (in your case, blue). If this happens the TV will shut down, probably due to either overheating or overvolting. To fix this issue, turn the appropriate SCREEN dial down until the lines go away. In your case, you want to turn the lower left dial down. Don't turn it too far down, if you turn it more than necessary the TV can give you an AKB error (noted by the STANDBY light flashing a sequence of 5 blinks).
Apr 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Jvc
I have the same problem on my tv - the colors are seperated - the picture is blury and in converge mode the colors will not line up.
Need to know if I need to go and buy a new flat screen tv.
Any advise is appreciated. Thanks
May 25, 2008 | JVC AV-56WP74 56" Rear Projection...
Hitachi 46BX01B 46" Rear Projection Television Logo
156 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
