Question about Logic Soundlab CPX1820 Car Audio Amplifier
Amp go's into protection
When you turn on the car the stereo turns on and then the amp, it comes on real quick then gos into protection.no sound comes on at all
  • Terry Thompson Mar 11, 2008
    i have the same problem to but it also does it when i plug in my rca cabels
    Problem Solver:
  • 4 Answers
Old post but your transistors might be blown
Posted on Apr 03, 2012
  • 82 Answers
Bad ground make sure you have a really good ground
Posted on Feb 07, 2008
  • James wood
    James wood Feb 08, 2008
    oh yeah you need it on like the body of the car and if there is paint or rust make sure you scrape it away really good were the ground wire touches
I have a JBL1004 amp in my ski boat. I killed the battery listening to the stereo and caused the battery to lose a cell and drop to 10 volts. The stereo cut out as one would expect. I have replaced the...
if the protect light comes on then you might not have enough voltage running to the amp so you would need to add a second battery just for that amp.
Jul 26, 2010 | JBL GTO1004 Car Amp
My sony xplod 1200 whatt amps red light keeps coming on all the wires are good when it gos to hit it gos red
check your ohm load on the sub and see if your amp can do the same, That is why every time it shuts off into protection mode. Check your gain level on the amp to this is not a volume knob for your amp, It is to get both the amp and cd player on the same page. Hope this was helpfull
May 19, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Stereo powers on, but whether on cd or radio, no sound comes from speakers. I feel like when it is cold out it does this more often, sometimes i think if the stereo is left at high volume when car is...
I would check to see if the vehicle came equipped with a stock amplifier sometimes the wiring comes loose from there or the amp just simply gives up.
Dec 26, 2009 | 2005 Nissan Pathfinder
Amp powers on but no sound!?
CHECK ALL YOUR POWER AND GROUND CONNECTIONS, THE SMALLEST PINCH WILL MAKE IT DO THAT.
Jun 18, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Fusion car amp turns on then gos in protect mode
look behind ur headunit could b a wire touching or a piece of metel
Apr 08, 2009 | Car Audio & Video
My jcpower car amplifier is not sound come out
you are probably getting a high voltage jump when you turn it up which will throw the amp into protect mode the only thing I can think of is trying a voltage regulator for your stereo
Apr 04, 2009 | Car Audio & Video
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Protection light
double check the blue stereo input wire to amp is this a new amp if not speaker channels in amp might be blown
Nov 08, 2008 | Kicker KX120.2 Car Audio Amplifier
My amp turns on and off
Sounds like there could be a short somewhere. Check to make sure that there aren't any (exposed/bare) wires touching each other or if there is a bare spot of wire touching something metal. Check both ends of all the wires. A speaker wire may have come lose and is shorting out against the frame or some other place. Usually if it goes straight into protection mode or you're popping fuses you have a short somewhere. I assume the capacitor you installed is somewhere on the power line, which would be for helping with
noise. You can also try disconnecting your amp from your stereo and see what happens but leave the speakers connected, you don't want to run the amp with out a load on it (the speakers). If your amp doesn't go into protection mode when the stereo is disconnected, then you have a problem with the stereo and not the amp, assuming you already checked for any possible shorts first.
Jun 15, 2008 | Pyramid PB1236GX Car Audio Amplifier
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
Logic Soundlab CPX1820 Car Audio Amplifier Logo
151 people viewed this question
Top Logic Soundlab Car Audio & Video Experts
Tygh Duval
Tygh Duval
Bill Boyd
FastHarley
FastHarley
Are you a Logic Soundlab Car Audio and Video Expert? Answer questions, earn points and help others
