Question about Brother PE-150V Computerized Sewing Machine
Brother PE150 Hi, I just got my PE150. It makes a few stitches, then the top thread winds loosley around the bobbin until the machine bogs down and stops. Any suggestions? Thanks, Kathy
  • slwallace Jan 18, 2009
    When placing the bobbin in and the thread goes as it should back up, so you have tow equal parts, with a two inch tail. I place fabric under foot. Locking foot down, I slowly move forward and a clunking sound is made. I life the foot to find a mass of thread evey langth, lose and knoted under the back side of the fabric. . I have cleaned the bobbin area of dust and fibers...Uncle, I give up, it sadens me, I am just starting out and have no clue where to go or due now.
  • Anonymous Mar 20, 2014
    brother innovis 4000 bobbin thread wont form stitch
    Problem Solver:
  • 3 Answers
I HAD THIS PROBLEM AND DISCOVERED I HAD USED THE BOBBINS FOR MY BROTHER REGULAR MACHINE. THEY ARE THE WRONG SIZE (TALLER). I PURCHASED THE RIGHT BOBBINS AND HAVE NOT HAD A PROBLEM IN THE 5 YEARS I HAVE OWNED THE MACHINE.
Posted on Jun 11, 2009
    Problem Solver:
You need to adjust your top tension and maybe your bottom tension ( the little screw on the bobbin cover) Also check your needle and make sure it's straight.
Posted on Feb 08, 2008
Adjust thread tension
Looking at a pic of this model, there are two dials on it. One near the top, one much closer to the needle. I believe the tension dial is the one that's close to the needle.
I don't quite understand what the problem is with the stitches from your description, but first try the tension dial. Reset it to zero and then try each setting, one by one, to see what happens.
If stitches are still wrong, a few things always to try when there are stitch problems. Clean well around the bobbin case, remove all lint. Do this often anyway, it's not good to let lint build up.
Try a new needle and a new spool of thread. Rethread the machine, a few times if need be. Try a new bobbin too, or wind a new bobbin to try from a new spool.
Try to get a manual for this machine. If Brother no longer has manuals, there are many sites that sell manuals for many machines. A manual can be your best friend when there are problems.
Jul 06, 2014 | Brother LS-2125 Mechanical Sewing Machine
Thread keeps winding around my bobbin holder. What could I be doing wrong?
Misthreading, most likely. Take all the thread off and out of the machine and clean the machine, especially around the feed dog and bobbin case areas. Rethread from scratch, remembering to thread the upper part of the machine with the presser foot up, and make sure the bobbin is sitting in the bobbin case right way around. Fetch up the bobbin thread and hold it and the top thread end together behind the presser foot while you take the first few stitches of the seam.
May 18, 2014 | Sewing Machines
Bobbins wind unevenly- tension issues
Sounds like it is actually the tension on the bobbin winder. Make sure that the thread is following the correct path to the bobbin. Other than getting it repaired, a stand-alone bobbin winder (avlb @ JoAnn's or online) for ~$30 would work. One brand is called the Sidewinder. Verify that your bobbins will work on it because some Singer bobbins will not. It's a nice accessory to have because it saves wear 'n tear on your machine plus you can wind bobbins without unthreading the machine.
FWIW, it is usually better to wind bobbins at a slower speed. Higher speed will tend to make the bobbin jump around and the thread to pop off. In addition, higher speed will tend to stretch the thread going onto the bobbin. The thread will not relax until unwound from the bobbin and stitched into your garment. It may cause the fabric to pucker as the thread relaxes. Slower is better!
Apr 15, 2017 | Sewing Machines
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
The thread keeps coming off the needing when i sew
Hello
I would suggest that you revisit the threading up in your manual and double check that the top thread is under tension.
However, if the stitiching on top of the fabric is wonky, this is your bottom tension too loose, and if stitching on the the underside of the fabric is loose, its the top tension causing it.
Quite often bobbin winding can be the cause of bad stitching so pull out the manual and wind a bobbin carefully following the instructions, making sure that the thread is under gentle tension as it winds. What you don't want is for the thread spool to bounce around as it unwinds onto the bobbin as this gives uneven tension of the thread and when you then stitch a seam, the thread relaxes in different amounts causing puckering.
So wind at 3/4 speed, and gently guide the thread onto the bobbin so it fills evenly across the whole core. And ensure there is tension on via a tension guide if your machine has one. If not, then place the curved handle of your scissors onto the top of the thread spool and hold it there as you wind, which holds the spool down and keeps the thread coming off it smoothly.
Always raise the pressure foot when you thread the machine so the top thread goes into tension fully. And new needle for each new sewing job is really important, make sure it is the right size and type of needle for the fabric you are sewing.
Aug 02, 2011 | Brother LS-2125 Mechanical Sewing Machine
Bobin jumps when sewing
Could be in around the wrong way, poorly wound or not under tension correctly. Or even the wrong bobbin for this machine.
I suggest that you check that the bobbin is correct, ie do you have several that came with the machine and are they all the same in shape and diameter? Consult the manual if you have one.
Nextly, wind a fresh bobbin taking the thread from the spool through the tensioner (if your machine has one on the top) and then onto the bobbin. Keep a little tension on the thread spool with the handle of your scissors to ensure that the bobbin winds smoothly and evenly. Use your finger tip to nudge the thread to fill all areas of the bobbin. You want a neat smooth wind so the thread will then flow smoothly off the bobbin when it is in the machine making stitches.
Now, load the bobbin into the bobbin holder or bobbin case as per your manual, ensuring the thread is correctly into the tension spring and bobbin is rotating the right way around.
Now thread up and test sew again.
Apr 09, 2011 | Brother Sewing Machines
Brother XL3030 SEWING MACHINE ..STRAIGHT STITCH LOOKS GOOD ON TOP OF FABRIC, BUT BOTTOM STITCHES ARE SKIPPING AND LOOPS FORM IN PLACES..YOU CAN PULL THE THREAD RIGHT THROUGH AND UNRAVEL ALL STITCHING! I...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
The top stitch on my machine doesn't seem like it is correct. It seems like it isn't going deep enough into the fabric and hooking well w/ the bottom thread. It almost looks like one long stitch all the...
Hi. I think I know what you mean--the top thread looks like it's just laying across the fabric, right? This is because either the top tension is too tight or the bobbin tension is too loose. (Either condition will look the same.) Try it with a different color thread in the bobbin, you can easily see the bobbin thread cross the top thread on top of your fabric. Here's what to do:
  1. since you should hardly ever need to adjust the bobbin thread, we'll start with the top thread.
  2. Make sure you thread the machine with the pressure foot UP (opens the tension disks) but adjust the tension with the pressure foot DOWN (closes them so they will adjust). Use a size 12 or 14 needle and good-quality thread (it does make a huge difference!)
  3. With different color thread on top and in the bobbin, stitch an inch or so and check the stitch.
  4. Slightly loosen the top tension (move the dial so the numbers go lower). Don't move it a lot, just a little bit.
  5. Stitch again and check. Repeat this process, stitching, checking, and gradually adjusting the tension dial until you don't see any of the bobbin thread on the top (or very, very little) and don't see any of the top thread on the underside (or very, very little).
  6. IF this doesn't get the balance adjusted, then you'll have to play with the bobbin tension. (But generally, once this is set, you shouldn't have to mess with it again.)
  7. There is a tiny screw on the bobbin carrier that tightens or loosens a very small metal strip (where the thread exits the carrier). To tighten the bobbin tension, screw this just a tiny bit to the right. (Turn it to the right to loosen the screw, to the left to tighten it.) Again, just make a small adjustment each time and recheck your stitches.
Few things about sewing are more frustrating than stitches that aren't balanced!
Sure hope this helps!
Robbie
Apr 22, 2010 | Brother XR7700
How do I insert the bobbin into an Elna Lotus sewing machine (the old Lotus with flip sides)
Elna bobbins have holes on the top, so wind the bobbin with the holes on the top too. The Lotus bobbin winder doesn't have a tension device, thread just goes through an eyelet. So, place your scissors curved handle on top of your thread spool as it unwinds the thread to ensure the thread then winds onto your bobbin evenly. Also watch the bobbin fill and give the thread a nudge with your finger tip to fill top and bottom as well as the middle part, you want it to wind evenly across the full width of the bobbin. When full, pop bobbin winder back to left, cut thread and pull off the bobbin.
Then place the bobbin into the bobbin holder with the holes on top, and pull the loose thread tail around anti clockwise into the tension device and gently "click" it into the tension spring with the tip of your finger while holding the bobbin still with your other index finger.
You will be able to tell if it is in tension if you then pull the thread and it doesn't come out of the tension spring. It should feel firm with resistance but still release thread to a gentle pull. tally_girl_6.jpg Now thread the top down to the needle and holding the end of the needle thread, hand wind the fly wheel towards you to lower the needle and pull up the bobbin thread. Close the bobbin cover.
Always hold the two thread tails at the back of the sewing area as you start stitching a seam until you have stitched at least 4 or 5 stitches to avoid thread jams.
Lotus is a lovely vintage machine - there is a user group on Yahoo Elna heirlooms where you can find lots of info and pictures shared by members.
Dec 07, 2009 | Elna 8007
Brother PE-150V Computerized Sewing Machine Logo
359 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
