Question about Acer Aspire 5610-4648 Notebook
Mouse Problems Hi All, I have a Toshiba Lap Top and my husband was using it today fine, then when I went on to use it the mouse (built in mouse) is just stuck, it will not move or click.....any ideas? Cheers Emma
  • jordan04 Feb 07, 2008
    Hi
    Yeah I have restarted a few times, and still nothing. It is like the computer thinks it has an external mouse and has canceled out the built in mouse pad, but I have not used any other mouse.
    do you know how I can activate it again?
  • jordan04 Feb 08, 2008
    thanks,
    will give it a go and let you know.
    Scholar:
  • 99 Answers
Did you restart the laptop?
Posted on Feb 07, 2008
  • Chris Liang Feb 08, 2008
    Now that you mention it, this happened to my dell one time. You could try downloading the built in mouse driver again. Just go under control panel under the mouse heading. Click Hardware, Properties, and Driver. Once you find that, try update driver. If that did not work, find the driver under the manufacturer's website.
Toshiba lap top with 1359 wireless mouse. Screen changes size 100% to something else often. Could this be the mouse? IF yes what should replace be? 4 years old.
I would first check to make sure they is nothing pressing on the Ctrl key on your keyboard. Holding down the Ctrl key while using the wheel on the mouse causes the zoom to change.
Feb 07, 2017 | Toshiba Computers & Internet
The cursor keeps on running
is this a mouse or trackpad mouse? disable trakpad in control panel and try external mouse or replace mouse
Apr 14, 2013 | Toshiba Computers & Internet
How to fix frozen mouse on Toshiba Lap top
I am not sure if you are using the built in keypad mouse or an external, if you are using an external and you are having issue, you might be having problem with the update driver if you installed SP1 on your computer, the first thing to try is another USB mouse, than can work 10 seconds after plugin it in, and you do not need to reboot.Tony
Feb 10, 2013 | IBM ThinkPad T20 Notebook
I have got toshiba lap top, it's mouse works in
Please boot in safe mode and click on start menu and type system restore. and open the system restore and select old restore point and restore it. After the restoring system will restart.
Aug 02, 2011 | Toshiba Computers & Internet
Put wireless mouse on a pavilion dv6 3031tx lap top and it worked fine then the other day lap top batters went flat and now mouse will not move pointer yes it still installed and working correctly have...
Please uninstall the whole driver package and also clean the registry fo the software via START--RUN--REGEDIT- and re-install the same. It would work FINE
Sep 01, 2010 | Microsoft Wireless Mobile Mouse 3000
Mouse quit working on my Lap Top it is a Aspire
First of all check whether the touch pad is lock (Fn+F7(?)). If you use an external mouse/ usb mouse, check usb cable connection, as long as you didn't drop it on the floor it should be ok. If the built in touch pad doesn't work, could be caused by ribbon cable connectivity that has dirt or moist. To fix it need to open the upper case
Apr 08, 2010 | Computers & Internet
My mouse on my toshiba satellite M55 S 3512 is not working. I spilt a little water on it a few days before. Quickly turned off my lap top and dried it up. A few hours later when i turned it on..the mouse...
Hello, this is Mike. I'm sorry to tell you that despite being having dried up the water you spilled more than likely left mineral deposits on the circuits in your mouse which cause it to short out and not function. If you are using an external USB mouse I recommend replacing it. If it was the touch pad on the laptop itself I must recommend you attempt to use your warrantee to have it replace or if it has expired I suggest you bring your laptop to a certified technician and have it repaired. I hope this helped you.
Jan 19, 2010 | Toshiba Satellite M55-S3512 Notebook
Mouse pad problem
Most of the time this is casued by a driver problem.
Some of the actual software installed to run the inbuilt mouse pad could of been lost or jsut outdated,
Remember microsoft operating systems are like a piece of space junk falling to earth, The closer they get to us the more falls of it untill its that unstable it just dissapears. Its intentionally built this way to create problems and get mroe people to update and buy newer systems and hardware :(
However Its worth visiting the acer website and look for your machines listed downloads,
Look through there for the mouse driver or sometimes they are calle HD input devices or Touchpads. Try downloading and reinstalling the driver again for that device.
You can check in device manager , start,controlpanel,system,hardware,devicemanager,
To see if there is a driver conflict.
Otherwise you could try rolling back your system to an earlier time when it did work through System restore, start, help,fixing a problem, using system restore to fix a problem, run system restore wizard,
This sometimes helps but make sure you have all the recently installed apps and other stuff you may of recently put on your pc as it literally rolls back the computer as if youve gone back a day or so.
Other wise if all else fails it could be a phisical hardware problem as in the touchpad has died. Usually te easiest solution is to do what youve allready done and just use a usb mouse unfortunetly.
If you have further trouble post back more info and i will try again to help,
Cheers
Steve.
Apr 01, 2009 | Acer Aspire 5610-4648 Notebook
Mouse
  1. Try another mouse - see if this is something about your Harma.
  2. If other mouse is behaving the same, and the problem with laptop, try working without any other USB devices - there may be a hardware conflict.
Dec 27, 2007 | Harma HM-703 (pn-3201676) Mouse
Mouse died
While using the mouse with the laptop you may use a proper mouse pad to avoid reoccurence
Sep 02, 2007 | Micro Innovations PD7250LSR Wireless RF...
Acer Aspire 5610-4648 Notebook Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
