Panasonic SA-DK1 DVD Stereo
I turn the unit off either with the remote or by pressing the power button and the unit automatically turns itself back on after a few seconds. I have to unplug the power to turn the unit off.
3 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: to purchase audio PCB
http://www.pcbnet.com/newcustomeroffer.asp
Posted on Feb 11, 2009
ravichetty
  • 158 Answers
SOURCE: Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Posted on Jul 31, 2009
How do I set the clock on my Panasonic SA-Ak270 mini stereo
The main unit is the SA-AK270. The entire mini-system is called the SC-AK270. The manual is available on the Panasonic support site: https://www.panasonic.com/au/support/manual-download/audio/hi-fi/sc-ak270.html . You do need to accept the Panasonic terms of use to download the manual. The check box is below the box with the Manual description and View link. The clock setting procedure is shown on page 14 (with the remote). The pictures of the remote control and main unit buttons are on pages 8-9 of the manual.
With the remote, press the Clock/Timer button until the Display is showing the time. Press Skip Back/Rewind or Skip Forward/Fast Forward within 8 seconds of pressing Clock/Timer to set the hour. Press Clock/Timer again and use the same Rewind/Fast Forward buttons to set the minutes. Note: the SC-AK270 uses a 24-hour clock.
You can also do this by starting with the Display button on the main unit. Then use the Skip Back/Rew and Skip Forward/Fast Forward buttons on either side of the Manual Eq button.
I hope this helps.
Mar 07, 2018 | Panasonic Audio Players & Recorders
How to reset factory stereo panasonic sc-vk825d
Turn the unit off then back to ON. Alternatively, turn the unit off, disconnect the AC power supply cord, and then reconnect it
OR....
While stopped and "DVD/CD" is the source, press and hold [L STOP] on the main unit and[h10] on the remote control until "Initialised" disappears from the television.Turn the unit off and on again. All settings will return to the default values
Jun 30, 2016 | Panasonic Audio Players & Recorders
How to hard reset unit without remote
  • Reset the unit to factory default settings as follows:
  1. Press [POWER] on the unit to turn off the unit.
  2. Press and hold [FAST FORWARD] and press [POWER] and [OPEN/CLOSE] on the unit at the same time for more than 5 seconds until "PLEASE WAIT" is displayed on the unit.
  3. The power is turned on and then turned off automatically.
http://service.us.panasonic.com/OPERMANPDF/SCBT200.PDF
Feb 18, 2014 | Panasonic Audio Players & Recorders
I have sa-pt350the power led is on but can not turn the unit on , can you help?
Does it try to turn on at all when you hit the power button? Watch the fan in the back and see if it turns for a second or two when you press power.
Jun 18, 2013 | Panasonic DVD Home Theater Sound System...
I have a panasonic cd stereo system SA-PM17. It's good, but i cannot turn it off. when i press turn off button, it turn off. then, i automatic turn on again in seconds. how to fix it
You need to take this unit to a qualified repair center. The problem seems to be either a malfunctioning switch, or the circuitry that operates the power on/off function. In either case, unless you are an experienced tech, in the interests of your own safety, you should not attempt to repair this yourself.
Oct 07, 2010 | Audio Players & Recorders
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
Trying to program cineplus remote for panasonic dvd player
Try this as all remotes work about the for manual setting.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 28, 2009 | Televison & Video
Jul 19, 2009 | Panasonic Televison & Video
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Panasonic CQ-DF401U
yes alll that problems exactly the same
Apr 14, 2007 | Panasonic CQ-DF401U CD Player
Televison & Video Logo
325 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
