Ricoh 3506 color copier
Hello, i am a copier tech and i need help on a copier... the erroe code is SC450 do u know what that is?
  • Anonymous Apr 29, 2009
    i have a ricoh aficio 3506, and it currently gives blank copies when it makes a copy
This is the first ricoh i have worked on and i can find a service manual.. Sharp and Copystar are the ones i have worked on for years.. im not sure how to get into the program loop to reset it.. i do know if i turn off then turn on it will clear it but i make a copy then it will jam and go into the error code.. im sorry but on this copier in a noob..
Posted on Feb 08, 2008
  • 1,326 Answers
Did you try to clear the code?
Minha Ricoh SPC 430DN deu erro SC 563, podem me ajudar. Sou do Rio de Janeiro - Brazil
  • Code: 563
  • Description: Pressure roller overheat 3 (software error)
    The detected fusing roller temperature stays at 230°C or more for 1 second.
  • Causes: • Defective PSU • Defective BCU
  • Remedy: 1. Replace the pressure roller thermistor (center). 2. Replace the PSU. 3. Replace the BCU.
Ricoh Aficio SPC430DN Error Codes List page 11 from 17
Esto dice que es posible que el Photo Conductor Unit Copier Drum es malo o el Color Copier BCU Engine Control Board es malo.
Jan 26, 2018 | Ricoh Office Equipment & Supplies
Error code sc450
450
D
Feed Development Motor Error
•???? Motor lock caused by overload.
•???? Motor driver defective.
The PLL lock signal remains LOW for 2 s while the feed development motor is operating.
May 21, 2014 | Ricoh Aficio 3045, 3035 Kit
Erreur 172 aficio 3506 COLOR
need to clean the optics for sc-172
Apr 06, 2014 | Ricoh Aficio 1232C Color Copier
Code sc450
replace the developing unit motor. .part number ax06 0240
Mar 20, 2014 | Ricoh Aficio 2035 Copier
I have error sc450 ricoh 3035
Check the developer unit. can the gears secion rotate normally?
Dec 15, 2013 | Ricoh Aficio 2045e Digital Laser...
Problem Ricoh CL 7200 error SC 542
fuser assy replace it and reset code or have tech come out and fix it
Jul 19, 2013 | Ricoh CL-7200 High Yield Toner Refill Kit...
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
Ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
Jan 15, 2009 | Ricoh FT3713 Copier
Color adjust error
problematic machine. transfer belt damaged(white spots ) for temp fix try manual registration from menu
May 09, 2008 | Ricoh Aficio AP3800C Laser Printer
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
243 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
