A replacement touchpad is now available from Ledgestone Technologies to replace various membrane keypad switches that are not available from the OEM.
These are in stock and can be shipped today from fixyourboard.
Find the full list of applicable models here:
Introducing the Ledgestone Technologies Touchpad
Step 1. Remove Original Plastic Bezel
BE SURE TO REMOVE POWER TO OVEN FIRST!
You are going to re-use the original plastic bezel. Remove the panel from your oven that contains the keypad and control board. Uplug the keypad from the control board. Remove the control board from the panel (4 screws).
Step 2. Remove Original Touchpad Membrane
With a heat gun, lightly heat the original keypad from the back of the panel. This will soften the adhesive. Gently but firmly push the old keypad off the bezel by pushing from the back of the panel on the keypad window. Carefully remove the original keypad membrane element. Most of the original adhesive should pull off with the keypad. Rub off any remaining adhesive.
Step 3. Install New Ledgestone Touchpad
Remove adhesive backing paper from the Ledgestone Technologies KP1308A1 Replacement Touchpad Membrane. Align and adhere new touchpad to recess in plastic bezel. Below are examples of black on black and gray on white. Gray also looks good on bisque or almond.
Step 4. Re-install Bezel on Oven
Re-attach control board to bezel, plug-in new keypad. Re-attach bezel to oven frame. Done!
Applicable Models
RBD276PDB10 RBD276PDB11 RBD276PDB12 RBD276PDB7 RBD276PDB8 RBD276PDB9 RBD276PDQ10 RBD276PDQ11 RBD276PDQ12 RBD276PDQ7 RBD276PDQ8 RBD276PDQ9 RBD306PDB10 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDB14 RBD306PDB15 RBD306PDB7 RBD306PDB8 RBD306PDB9 RBD306PDQ10 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDQ14 RBD306PDQ15 RBD306PDQ7 RBD306PDQ8 RBD306PDQ9 RBD306PDT11 RBD306PDT12 RBD306PDT13 RBD306PDT14 RBD306PDT15 RBD306PDZ10 RBD306PDZ7 RBD306PDZ8 RBD306PDZ9
Original Whirlpool Touchpad Part Numbers
4451969 4451970 4451975 4451976 4451977 8300431 8300432 8300437 8300438 8300439 8300640
Sorry, it's RB270PXK.
Thanks for trying. That's what I did.
That model number is not working for me. please find the model number on the machine. either around oven door or drawer on frame
