Question about HP OfficeJet 6110 All-In-One InkJet Printer
How to set time clock - HP OfficeJet 6110 All-In-One InkJet Printer
  • OnkarSingh Feb 08, 2008
    It is very good answer. Thanks
  • 82 Answers
How to set clock ON GE- JB860SJ1SS
RANGE SETTING THE CLOCK NON-ELECTRONIC CLOCKS: To set the clock:
  1. Push the center knob in.
  2. Turn the clock hands to the correct time. If the Minute Timer pointer should also move, let the knob out, and turn the Timer pointer to OFF.
DIGITAL CLOCKS: To set the clock:
  1. Push in the center knob of the Minute Timer.
  2. Turn knob in either direction to set the Digital Clock numerals to the correct time
ELECTRONIC CLOCKS: To set the clock (models with Clock or Set Clock pad):
  1. Press the Clock pad
  2. Press the + / - pads or number pads (depending on model) to set the time.
  3. Touch the Start pad. The time of day will show in the display.
To set the clock (models without Clock or Set Clock pad):
  1. Press and hold the + and - pads for 3 seconds.
  2. Press the + / - pads to set the time.
Nov 05, 2017 | Audio Players & Recorders
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    I have a c218 and i can't set time
    Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
    Don't expect this clock to set the time by itself. It is not an atomic clock.
    Oct 06, 2012 | Sony Bedside Icf-c218 Automatic Time Set...
    How do you set the time on Brookstone iDesign Cube Clock Radio?
    Simply HOLD down the "CLOCK SET" button for ~3 secs and the time will flash... Rotate the dial around the SNOOZE button to the hour you want; click the "CLOCK SET" button again for the minutes and rotate the dial again... Hit the "CLOCK SET" button one last time and you're done!
    Jul 05, 2010 | Brookstone (467522) Clock Radio
    I have a 'relaxed nature sounds lcd clock' with no instructions
    Moderately difficult, but not impossible. ;) I picked up this clock @ second hand store with no instructions and was able to figure it out how to set it in about 15 minutes. I liked the calendar feature on the face and the LCD (as opposed to LED because I prefer my bedroom dark when I sleep).
    When setting this clock, one of the keys is to pay attention to the the icons displayed on the face toward the lower left. Default "MODE" is time set. To set the time: Press "SET" followed by either "HOUR" or "MIN" while the display is flashing to increment the hours and the minutes to the correct time. As previously state, the default "MODE" is time set.
    Pressing "MODE" one time accesses a secondary clock that you might use if you regularly travel to another time zone (new icon w/ 2 clocks appears). Setting the secondary clock uses the same method above.
    Pressing "MODE" a second time accesses the first alarm setting (alarm clock icon starts flashing). Same method to set.
    Pressing "MODE" a third time accesses the secondary alarm setting (second alarm clock icon appears and begins flashing). Same method to set.
    Pressing "MODE" a fourth time accesses a timer (hourglass icon appears). Same method to set.
    Pressing "MODE" a fifth time allows you to set the calendar (calendar year appears where the digital clock display was). Press "SET" to change the date: "HOUR" increments the month; "MIN" increments the day; "MODE" increments the year. Press "SET" again to exit.
    Pressing "MODE" a sixth time returns to the default time set mode.
    I hope this helps someone! God's blessings in Jesus Christ! ~Thomas
    Mar 09, 2009 | Audio Players & Recorders
    How do I set the time on my Pioneer RT500?
    Hi!
    Please follow the instructions given below... =)
    Setting the clock
    The clock is set to the correct time automatically, but it
    can also be set manually. The clock can be set for
    daylight saving time and time zone.
    Preparation:
    • Turn ON the TV and set it to the video input mode.
    • Select “CLOCK” from “SYSTEM SETUP”. For the
    procedure, see steps 1 to 3 in “Using the SETUP
    MENU”
    1 Press SETUP while the DVD and video tape is
    stopped.
    The SETUP MENU screen will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    SETUP MENU
    ENTER/
    SELECT ENTER RETURN BACK SETUP END
    SELECT
    2 Press  or  to select the desired menu and
    press ENTER.
    The submenu screen of the selected menu will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    LANGUAGE
    PARENTAL
    CLOCK
    DISC SETUP
    OTHER
    SETUP MENU
    3 Press  or  to select the desired submenu and
    press ENTER.
    The screen for the selected submenu will appear.
    CLOCK (manually)
    You can manually set the date, year and present time
    with the remote control.
    Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
    1 Select “CLOCK” and press ENTER.
    01/01/04 12:00AM
    2 Select the desired items using  or  (month,
    date, year, hour, minute and AM/PM) then press
    ENTER.
    3 Press  or  to set the value of the selected
    item.
    • For the minutes, press  or  once to set the time
    minute by minute, or hold down either of buttons
    for several seconds to set the time in 10-minute
    intervals.
    10/30/04 10:200AM
    4 Repeat steps 2 and 3 to set the date, year and
    present time, and press ENTER. The SETUP MENU
    will close.
    This completes clock time setting.
    AUTO CLOCK
    You can automatically set the clock by turning “ON” the
    AUTO CLOCK function.
    When you want to set the auto clock function to “OFF”,
    select “AUTO CLOCK”, press ENTER and select “OFF”
    from the list.
    Auto clock setting
    Preparation:
    You must connect the antenna or cable before connecting
    the AC cord to the power source.
    Wait 30 minutes with the power turned off, after the
    antenna or cable is connected, for the auto clock
    feature to activate.
    After the clock is set automatically, you may have to set
    the time zone and daylight saving time. (See page 26.)
    Press STANDBY/ON to turn on the DVD/VCR after the
    auto clock operation completed.
    • When shipped from the factory, the “AUTO CLOCK”
    option is set to “ON” position.
    • If you turn the DVD/VCR on during auto clock
    setting, the clock is not set.
    • After a power failure or disconnection of the power
    plug, the clock setting will be lost. In this case, wait
    30 minutes before turning the DVD/VCR on.
    • With cable box connection, if the auto clock setting
    is unsuccessful, select the PBS channel carrying
    the XDS information, then turn the DVD/VCR off.
    After 30 minutes, turn the DVD/VCR on.
    • If the clock is not set automatically, set the clock
    manually.
    STANDARD TIME (Time zone)
    In the rare event that you live within the broadcast range
    of two stations in two different time zones, the DVD/VCR
    may recognize the wrong station for the auto clock set.
    To correct the situation:
    Select “STANDARD TIME” and select the time zone from
    the list below.
    Selectable time zones and correction times
    ATLANTIC: GMT – 4 hours
    (GMT: Greenwich Mean Time)
    EASTERN: GMT – 5 hours
    CENTRAL: GMT – 6 hours
    MOUNTAIN: GMT – 7 hours
    PACIFIC: GMT – 8 hours
    ALASKA: GMT – 9 hours
    HAWAII: GMT – 10 hours
    AUTOMATIC: AUTO SET
    Note
    • When shipped from the factory, the “TIME ZONE” is
    set to “AUTOMATIC”.
    • After making the auto clock setting, in some cases
    the clock may display another time zone. You can
    correct the clock by selecting your time zone
    setting above.
    • When the clock is not set or you set the clock
    manually, the time zone setting is not available.
    DAYLIGHT SAVING TIME
    You can set the clock to daylight saving time automatically
    or manually.
    To select daylight saving time, select “DAYLIGHT
    SAVING TIME” and select “ON”, while to cancel the
    daylight saving time, select “OFF”.
    ON: For manual setting (forward 1 hour)
    OFF: For manual setting (back 1 hour)
    AUTOMATIC: For automatic setting (read XDS in
    the signal)
    Note
    • When you want to set daylight saving time, on the
    first Sunday in April you set it to “ON”, and on the
    last Sunday in October you set it to “OFF”.
    • When shipped from the factory, the “DAYLIGHT
    SAVING TIME” option is set to “AUTOMATIC”.
    • When the clock is not set, the daylight saving time
    • When there is no daylight saving time in your area,
    always select “OFF”.
    Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
    Setting the time
    On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory.
    Now, to those switches: The first (from the left) is DST = Daylight Savings Time - right now you'de set this to "ON."
    The second switch is Time Zone: PST, MST, CST, EST (Pacific, Mountain, Central, Eastern). Set the switch to the time zone you are in.
    The third is just the brightness.
    Now, to set the time itself:
    1 - Turn the clock face back up to where you can see it.
    2 - LOOK AT THE CLOCK - LOL! This is an atomically set clock - you shouldn't need to set the time. The atomic clock bounces off of satellites all around the world. There is literally little to no "dead zones" for the clock, so you should never have to set your clock - just set it up like I state at the beginning.
    Good Luck!
    Mar 16, 2008 | RCA RP5420 Clock Radio
    Cant set time
    Rondart
    Rank:nonexpert_s.gif Apprentice
    Rating: 0%, 0 votes
    On the back of the clock - left hand side if you've laid it down on it's face - is a row of switches. You need to start the time set-up with the clock having been unplugged so there's no time set in the memory5.gif.
    Good Luck!
    Mar 10, 2008 | RCA RP5420 Clock Radio
    Centrios Atomic Desk Clock/Temperature
    Here is how you adjust the time zone:
    1.) push MODE till "AL" appears after the minute.
    2.) tap "SET" (tap means push but do not hold) and time zone will advance.
    3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
    Nov 08, 2007 | Audio Players & Recorders
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    50 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
