Question about Dell 1600n All-In-One Laser Printer
Dell 1600n Open Heat Error, Low Heat Error
After a particularly nasty paper jam, I received an Open Heat error in my Dell 1600n printer. After reading online, it seemed that the problem may be that I needed a new fuser. I ordered one and installed it. After I turned the printer on, it started to smell like something was burning and I believe the display had a message about overheating. Eventually, Low Heat Error was displayed. I turned the printer off, then on again and got an Open Heat Error message, which is now all I can get after turning the printer off and on.
It sounds to me like the safety fuse that I've seen mentioned in discussion elsewhere regarding this problem may have opened. If that's the case (i.e., the printer overheats whenever it's turned on), does that mean my problem lies somewhere besides the fuser (I expect that it does)? Also, is it possible to buy and install a replacement fuse, or is the new fuser now toast (as the first one also is if the same thing happened
  • 1 more comment
  • Anonymous Oct 21, 2008
    I had the same problem and i installed a new fuse but this burns as well. so i spend about 100.-  for nothing.
  • LynneSkysong Nov 18, 2008
    I keep getting "low heat error." It hasn't overheated (that I know of) or had anything more that an occasional printer jam. I haven't tried replacing the fuse, but it sounds like maybe I shouldn't bother anymore...
  • Anonymous Apr 14, 2009
    I have the same issue sorry but the reply of check the voltage of the fuser is compatible with your printer is not a great answer unless you want to explain more because from what I am gathering just like me the problem has happened with the exsisting fuser not a new fuser.
Buy a new printrer
Posted on Feb 23, 2008
  • 679 Answers
"Open Heat Error" Means --- You need to make sure the voltage of the fuser is compatible with your printer.
Please rate the solution.
Thanks for using FixYa.
Posted on Feb 09, 2009
The display reads open heat error. What is this and how can i fix it? I do not know where the manual is.
An open heat error on a 1600n printer is a fuser error. You would want to make sure that the printer is not plugged into a UPS or power stripe. You would also want to make sure that there is plenty of clearance around the printer. If these are already in place then the fuser would need to be replaced. This is not normally a customer replacable item.
Aug 07, 2010 | Dell 1600n All-In-One Laser Printer
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n error - What does "open heat error" mean
1. Please check the thermostat in the fixing unit.
2. It may open due to over heat. replace it. clean thermister.if spoiled replace it also.
Jul 15, 2010 | Dell 1600n All-In-One Laser Printer
It say error JAM 1 what does that mean
Look inside printer to see af any paper is in there if so remove.Pull out paper tray and clean pickup roller (roller that picks up paper from tray)if the roller has film on it it will cause jam1 error
Mar 22, 2010 | Dell 1600n All-In-One Laser Printer
How do I repair an "open heat error"?
I'm sure it's not the answer you're looking for but the "Open Heat" error is related to the printer's fuser, switch mode power supply or temperature control thermistor. More than likely it's the fuser which needs replacing and you'd need to contact Dell for a replacement. If you google for "1600n fuser" you'll also come up with several retailers with fusers in the $80 range as opposed to Dell's $140+.
Jan 21, 2010 | Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Grey arm is in place. cannot find any paper anywher that is a jam
this can happen if any of the contact points on the cartridge are even remotely scratched or if the cartridge is "low" even if it doesnt say its low
Please Rate Me
May 28, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600N warming up message
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Sep 16, 2008 | Dell 1600n All-In-One Laser Printer
Open heat error
Most "Open Heat Error" messages are caused by a bad fuser. Order a new fuser from Dell.
May 22, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600N Multifunction printer problem.
Fuser issues - if problem is reoccuring then you are looking at more expense, are all vents free of obstructions (folders leaning on machine sides/rear) is machine being flogged, is power supply consistent, maybe even fuser bought was faulty, many options, try doing a warranty claim on fuser or replace again, even better get another printer, welcome to our throw away world!
Oct 31, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
1,537 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
