Question about Freezers
Side by side Ref/Freezer
My ice dispenser is crazy.. I have replaced the solenoid (per repairclinic.com) and I still have to fight it for ice. When I push the lever there is a delay, sometimes I have to switch to water and back to ice. Usually it malfnctions when I have company and its a pain in the butt. Could it be the circuit board behind the controls or the switch that tells it that the door is closed?
  • Samd007 Feb 17, 2008
    I'll try, I have a touch switch not a sliding one. I'll follow up on the board. Thank you
    Sergeant:
  • 288 Answers
Based on the info you just gave about moving the switch from water and back to ice, I would say the switch. It is a much cheaper part too. If you are capable, and it sounds like you are, remove what you need to to get to the switch. By-pass it by connecting the wires together. If the dispenser works instantly, that's it. If not, then you need to follow the path, probably back to the board.
Posted on Feb 16, 2008
Refrigerator side not cooling and freezer not freezing properly. Ice maker not making ice!
call your local repairman . it possibly needs freon added and only certified people can do it .
Mar 17, 2016 | Samsung RS261MDBP Side by Side...
IHave a ge side by side refrigerator not cold enough and freezer has frost on back wall and some items are not frozen
your GE self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch. If you have a GE profile, they have a motherboard at the back of the ref. if all i the part i mentioned are working, just replaced the motherboard. at searspartdirect.com
Apr 06, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
ED5GTQXKQ01 Whirlpool Side by Side motor not turning.
This is a complicated system to diagnose, and one not recommended by the average DIYer. I would recommend in this case to have a qualified whirlpool technician at least inspect and give you a diagnosis. Due to its complicated nature, and the difficulty in accessing all the parts needed to test, if done incorrectly, you could further damage the door, or the dispenser module.
Mar 29, 2010 | Freezers
LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Sep 15, 2009 | Freezers
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
Sep 04, 2009 | Whirlpool Freezers
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 | Freezers
Freezers Logo
71 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
