Please help Please read the post that you have posted back to in the past. How do i remove the flyback transformer cables? http://www.fixya.com/support/t244664-rca_d56w20_no_power_whistling
  • mchipser Feb 10, 2008
    I got the groment off... i have tried the clips yet.. I did get the black cable out im not sure if it broke but the is a little wire sticking out of the end of the black cable.. I haven't got the new board in yet... Waiting to see if i can afford it.. Based on the picture for the new board it does not appear to have new cables and / or groment..
    Here is a link for the board
    http://tinyurl.com/2h7cy4
    Genius:
  • 1,030 Answers
Sorry about that my new email is Willie@FORDTV.COM These are some of the hardest cables to remove. the black wire will come out but you have to pull straight up and with some force. with steady force not quick jerck or you can break the wire. the big red wire usally has a clip gromet under the boot slide the rubber boot up the wire. remove this gromet is difficut. i usally break about 75percent of the one i try to remove. some technicians say freeze spray helps..i never use it the groment holds the wire in the hole there are two slots on the side you that push in.. question did the new flyback on the board have a groment..just in case break the old one?
Posted on Feb 08, 2008
REPLACEMENT FLYBACK TRANSFORMER SONY TRINITRON CRT TV KV-2062E IS REQUIRED
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 02, 2016 | Sony Televison & Video
What is the flyback transformer number of sanyo tv ST-21SE1
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Flyback transformer data is given. Search the site with the keyword "Flyback Transformer". Type in these words in the search box located at the top right of the display window.
Jun 20, 2015 | Sanyo Televison & Video
The tv turns on, i can see picture but its too dark.
Try adjusting the screen control on the flyback transformer. It may be accessible without removing the cover . The access hole is usually on the back of the set and wil be marked "screens" Failing that please post the model number
Mar 12, 2009 | JVC AV-27530 27" TV
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Oct 06, 2008 | RCA F32450 32" TV
Flyback transformer?
Its either the flyback or a regulator. But i would need the model number of your set in order to know for sure. Please reply to this same post with your model number.
Aug 02, 2008 | Televison & Video
Wont turn on smell burning
Can you remove the rear panel and check if the hissing is coming from the flyback? Which is a large transformer with a large red wire coming from the top of it? If so can post a link where you can get a replacement their not exspensive and their easy to replace. If its not coming from the flyback post a picture of where the hissing is coming from and I will identify the parts for you, But I feel its the flyback due to the hissing. respond to this same post so I have your correct model number when you reply.
Jun 25, 2008 | Zenith R57W46 57" Rear Projection...
Magnabox tv noise flyback transforma
Post the model number of your magnavox and I will post a link where you can get the correct replacement flyback for your model and get free tech support to help you install it.
Jun 19, 2008 | Televison & Video
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
