Question about Watches
Seiko kinetic keeps stopping
  • elinchrom999 Dec 05, 2008
    Exactly same problem-on my Seiko Kinetic. Maybe needs cleaning?
    New Friend:
  • 17 Answers
The Seiko Kinetics use a capacitor instead of a battery. The pendulum swings (you can watch the pendulum swing through the clear window on the back of some Kinetics) and the swinging pendulum charges the capacitor.
I have replaced over 100 capacitors for other people and in my experience capacitors will last 2 to 5 years depending on the model of the watch watch. The early models such as the 5M23 series will not last as long as the Auto Relay for example.
The capacitor itself costs 20 dollars and an experienced person will probably charge 40 to 60 dollars more for installation.
Since the case will be opened away have the innards lubricated as per Seiko's specific oils and techniques.
An ethical repair person will also install a new gasket for the back.
The gasket can dry and shrink, which allows contaminants to enter the watch innards.
Posted on Nov 21, 2014
Had the same problem on my Seiko kinetic a good few years back and I had to get a part replaced in it
Posted on Dec 02, 2009
I habe seiko kinetic work and stop work
Posted on Jan 22, 2009
5 Suggested Answers
  • 8 Answers
SOURCE: seiko watch band
very tightly
Posted on Jan 02, 2008
Techjoel
  • 79 Answers
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Posted on Jun 05, 2009
SOURCE: my seiko kinetic watch stops
Further to the previous solution...
Despite Seiko's claims regarding never having to change the 'battery', the power storage unit or ECU in Seiko-speak (not technically a 'battery') does eventually need replacing. From the symptoms you describe, it sounds as if the 'battery' on this watch is on its last legs as it is no longer charging properly. The good news is that it doesn't have to be an expensive job to have it replaced (providing you avoid going through the local jeweller <==> Seiko chain!). There are companies on the Internet who offer a replacement 'battery' service. I've used one in the past and was very satisfied with both the cost and the good service. A Google Search will probably return a choice of several in your country. Btw, if you have had your Seiko Kinetic for a few years, its probably worth paying a bit more and having it overhauled (clean and oil the movement and replace the watertight seals) at the same time.
Posted on Jul 06, 2009
SOURCE: My watch, Seiko Kinetic Auto-Relay (5J22-OD60), no
You have a bad capacitor. You can either try to repair this yourself with a special upgrade kit for about $20 (and maybe screw it up) or pay an expert who will do it right for $67.
http://www.qualitywatchrepair.com/seiko_kinetic.htm
For an extra $20 he'll do a pressure test on it to be sure it is water-proof but since this is a pro you really don't need to worry about it on a non dive watch.
Posted on Jun 13, 2010
Charge indicator on my Seiko Kinetic watch does not work. Watch keeps good time. Is there a fix?
Bill, when you say "does not work" I am going to guess you mean that the second hand does not sweep as it should, so you do not have an accurate indication of remaining capacitor charge.
There are many other malfunctions of the Indicator on a Seiko Kinetic but I am guessing that is your current watches malfunction.
The button at 2 o'clock depresses a tiny lever inside the watch, and that in turn releases a discharge from the capacitor.
The strength of that discharge swings the indicator.
The lever itself is very very small, and can be misaligned, very commonly after capacitor replacement.
Actual breakage of the lever is quite rare.
Does the button have a definite detente when you press it?
Or is it instead like pushing on Jello.
Is the button spring loaded such that it returns to the neutral state on its own?
It is actually a quick diagnosis for anyone familiar with Kinetics; as a quick peek will tell if a broken lever, absent button gasket, need of lubricant, etc.
Aug 08, 2016 | Seiko Kinetic watch
How to get bezel for seiko SQ 50
All parts can be purchased by phone from the Seiko New York call line. They are extremely helpful and get your part as soon as it is available. This is the TRUE Seiko parts line - NOT an off brand. I have used this call line numerous times over the last couple of decades for my husbands Seiko watches. the phone number is:
(201) 529-5730 If they cannot get it no one can!
Jun 23, 2014 | Seiko Kinetic watch
Seiko 7d48 battery
i would say when the watch stops, to save battery power pull the winder out when not in use the watch will stop.
Jan 01, 2014 | Seiko Watches
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 24, 2009 | Seiko Kinetic watch
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Watches Logo
1,106 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
