Question about Lakewood Oil-Filled Electric Radiator Heater
Over heating on corsica91
Changed the thermustate and motor to the fan. drive about 5miles maybe and the car makes a funny noise I pull over and it cut off. no smoke or water needed when it does that.
  • 82 Answers
What kinda noise squilching pinging bubbling or what
Posted on Feb 07, 2008
When is the cooling fan supposed to come on ,car not over heating running ok but funny noise when driving ,only when car is moving can't hear from out side only from inside
The cooling fan comes on when the vehicle reaches a designated temperature to keep the vehicle running at optimal performance. It sounds like your is not kicking on correctly or not at all. It may need to be replaced. See if you can find out where the noice is coming from and post it if you can do so safely. Please advise
Jul 07, 2015 | 2006 Mazda 3
2004 chevy cavalier/ a noise suddely became noticeable coming from near the fan or ductwork under the dash.It sounds as if the fan blades are striking something and also sounds similar to static . It...
My car's glovebox door/trim was rattleing makeing a static noise. I had a friend push up on the trim while it was making the sound, and it stopped, so I just jammed a small wad of tissue up between the trim, and that solved it for the time being. Funny thing tho, after I had my tires balanced, the noise went away never to return. You could have a faulty blower motor tho, if the tissue don't work, or you can't stop it by applying pressure to the trim, look into blower motor replacement.
Dec 16, 2013 | Cars & Trucks
Engine overheat and no heat
Maybe your radiator is clogged.
Mar 12, 2017 | 2001 Nissan Sentra
Aeg santo feezer getting hot on the sides and making a funny noise
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink
May 11, 2012 | AEG Refrigerators
I have a 2001 intredpid 3.2 that is overheating. The passenger side cooling fan will not cut on. I just changed the fan motor yesterday and I still haven't seen the fan cut on. Since I changed the...
First off, there is a number of reason why u are hearing bubbling noises but first lets address your Fan. I take it that u have a 2 fan setup, when you say " The passenger side cooling fan will not cut in". This fan is associated with the AC, and only comes on when the AC runs. Helps with better air flow thru the condenser which is in front of the rad. Does the AC work?
OK, now for the bubbling noise. First off the noise indicates to me that maybe you still have problems with over heating. Does the fan on the drivers side come on? Where is the Temp gauge at when it does come on? You might have air in the system, which canbe bleed thru a bleeder screw on top of the motor. I found the best way to do this is have the frt of the car elevated abit with the car off when filling the coolant reservoir. Other things associated with over heating, thermostat not opening, or stuck open. Head gasket, possibly exhaust is getting into cooling system, building up pressure which vents when you shut engine off. Hench the sound. Water pump possibly leaking.
Aug 30, 2011 | 2001 Dodge Intrepid
My heat in my van is not working its blowing out cold air and making funnying noises.
Bad thermostat or bad heater core may be the cause of no heat. The noise would be the fan motor. Have it checked.
Nov 04, 2010 | 2000 Ford Windstar
The heater in my 2000 chevy malibu is making funny noises ... speeds one and two dont work.. havent since we bought the car... for 2 years now.. but what is that sudden noise that came on yesterday... like...
I have ran into the same problem, there may be something has got into fan cage. remove fan motor and investagate to see if it is blocked, or if fan is going bad. it is behind glove box, to remove. remove lower right dash insulator panel from under glove box. slide bcm aside for room to get at fan motor. remove 3 screws from fan motor, and remove fan after disconnecting wiring. the blower motor resistor is beside fan motor. the resistor will make ya lose 1 and 2 speeds. for it is a 5 step resistor.
Oct 29, 2009 | 2000 Chevrolet Malibu
The heater will not work in the car when switch for the heater fan is on.makes a funny noise when you turn on the heater fan while driving.
You may have a bad fan motor or the basket on the motor has debris in it. Most times rodents will
get into pocket where the fan is and fill the basket with everything and anything they can get to. Try taking the fan out an inspect it for this and remove anything that may be in it. If this has occurred quite possibly you may have to replace it.
Aug 11, 2009 | Honda Accord Cars & Trucks
Faulty Air Conditioning in a 2000 Nissan Pulsar N16
It's quite possible that your A/C compressor is locking up, thereby causing excessive load on the engine.(translates into lack of power to drive wheels) Typically there are signs, such as the noises you heard, or a slipping or thrown belt. If the compressor is locking up, being belt driven it will draw excess power from the engine. It's also possible that the compressor clutch in conjunction with compressor is going bad as well (both are usually related). That would cause excessive amperage to be drawn through the circuit, thereby blowing the fuse. Ultimately, it sounds like you have figured out your own problem, but I hope what I've posted helps.
Nov 12, 2008 | Nissan Pulsar Cars & Trucks
Lakewood Oil-Filled Electric Radiator Heater Logo
94 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
